1995 Passport V6 Crank No Start
TLMG21700
07-10-2006, 01:11 PM
:banghead: PLEASE HELP!!!!!!!!!!!!!! I OWN A 1995 HONDA PASSPORT AND IT CRANKS OVER BUT IT DOESN'T START I HAVE SPARK GOOD COMMPRESSION JUST NO FUEL I HAVE POWER AT THE FUSE THE RELAY BUT NO POWER AT THE PUMP I JUST REPLACED THE PUMP THINKING THAT WAS THE PROBLEM BUT IT WASN'T ALL MY FUSES AND RELAYS ARE GOOD IF YOU CAN HELP PLEASE DO
I DID WASH THE MOTOR AND THAT IS WHEN IT WOULDN'T RESTART PLEASE HELP:banghead: :banghead: :banghead: :banghead: :banghead:
Ramblin Fever
07-11-2006, 07:49 AM
Check all of your ground connections, i.e battery, starter, alt, etc
How old is your alternator?
Could also be your starter.
TLMG21700
07-11-2006, 10:25 AM
the alt is about 6 months old the starter works fine it is weird i just don't have the power at the pump i am thinking i have a broken wire is that common? and if it is where is it around
Ramblin Fever
07-11-2006, 12:14 PM
Hopefully someone here can chime in; I don't know enough about the fuel pump, connections, etc on these trucks.
TLMG21700
07-11-2006, 08:05 PM
i found my problem today there is a plug under the pass. seat that connects the inside harness to the outside harness well the plug was lose i put i zip tie to put them together and that fixed the problem thanks for your help
