Automotive Forums .com - the leading automotive community online! Visit IgorSushko.com and see what it's like racing in Japan
Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Chevrolet > Aveo
Old 07-09-2006, 06:31 PM   #1
timguyli
timguyli Normal reputation
what rims will fit?
Help! I slammed a pot hole and destroyed 2 rims on my 04 Aveo. I hammered them back so they would hole air but thats just a temp fix. Has anyone put real rims on theirs? Mine are the stock steel rims. Thanks!
timguyli is offline   Reply With Quote
Old 07-10-2006, 05:39 PM   #2
mikedudley17
mikedudley17's Avatar
mikedudley17 Normal reputation
Send a message via Yahoo to mikedudley17
Re: what rims will fit?
well im runnin 17s on mine but ive seen elsewhere on the net of people claimin 18s but i aint so sure bout 18s cus as it is i dont have much clearance in my tire well. but it is entirely possible. i would recomend no bigger than 17s tho.
mikedudley17 is offline   Reply With Quote
Old 07-11-2006, 12:36 PM   #3
phantomcobra
phantomcobra's Avatar
phantomcobra Normal reputation
Don't forget changing tire sizes will also make your speedo off. Larger tires means you are going faster than the speedo says.
66 Charger (the ORIGINAL!!) (auto, 2 dr, 7.2L)
67 Chrysler Newport (auto, 2 dr, 6.3L)
98 Mazda Millinia (auto, 4 door, 2.5L)
04 Cavalier (auto, 4 door, 2.2L)
*seems like my engines keep getting smaller
phantomcobra is offline   Reply With Quote
Old 07-11-2006, 12:50 PM   #4
G-man422
G-man422's Avatar
G-man422 Normal reputation
^ It doesnt affect it that much though.
- 1997 Acura Integra
- 1993 Toyota Paseo
G-man422 is offline   Reply With Quote
Old 07-12-2006, 12:55 AM   #5
aveo81
aveo81 Normal reputation
you can fit 18s if yu go to a 35 side wall and you dont have to change teh speedobut you might want to up the calipers just for braking emergenciesanyone who dose bigger rims should always do the brakes roters expecially if your going 3 to 4 sizes bigger..the rims will roughin up the ride but lookis damn great
the bolt patern is 4 by 100 mm
i am running enkei RZ - 5
but there is cheapers ones made by core racing that almost look the same
aveo81 is offline   Reply With Quote
Old 07-23-2006, 11:33 PM   #6
mikedudley17
i had i beleive 205/45/r17 on my rims and i had to downsize to 205/35/r17s because there was not enuff room up front when i turned. i aint to sure if those are the right sizes or not but just keep in mind when doin this to keep a small enuff tire because the tires would rub on the inside and ate the s$*t out of my tires. just more food for thought. altho the 45s looked better cus it gave the car a more lowered look.
Old 09-02-2006, 08:53 PM   #7
timguyli
i just want plain ole 14" rims to replace what i got... anyone have any stock rims for sale or rims that can use the original tires? Thanks
Bookmarks
Google
Web AF
