Leaky o2 sensorALLWORLD19 07-09-2006, 06:50 PM Has anyone ever heard of putting some kind of putty or dope on a leaky o2 sensor to let it harden around the o2 sensor to stop it from leakin? thank you richtazz 07-11-2006, 07:46 PM There is no point, as o2's get VERY hot and whatever you use will just burn off. Replace the sensor, because if it's leaking, the sensor isn't functioning and will screw up your fuel metering causing fuel mileage/performance to fall in the toilet. ALLWORLD19 07-11-2006, 08:13 PM The mechanic says the putty or dope is made for exhausts and won't burn off my check engine light is not on yet. RJ MALIBU 07-14-2006, 07:49 PM much easier to change it now than when it does go bad u wont have putty all over it Automotive Network, Inc., Copyright ©2012
