Automotive Forums .com - the leading automotive community online! Visit IgorSushko.com and see what it's like racing in Japan
Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Chevrolet > Astro > M Bodies
Old 07-06-2006, 03:59 PM   #1
eohrnberger
eohrnberger Normal reputation
Send a message via Yahoo to eohrnberger
2000 Safari 70K miles floorboard vibration @ 70-80
I've got a 2000 Safari two wheel drive with around 71K miles on it. I've recently replaced the front brake rotors and pads, as well as put new tires on it (properly balanced on install).
A nagging vibration at highway speeds is bothersome (70-80 MPH). You don't really feel it in the steering wheel or the brake pedal, but you do feel it when you put your feet flat on the floor boards. You also feel it in your seat. It seems to have gotten worse in the last 10K miles or so, and I figured that the old tires were the source, but since I've put new tires on, it would seem to not be the case.
When I drive it on the express way, and put it in neutral, the vibration is unchanged.
Anyone else have something like this going on? Should I re-balance the drive shaft or something?
2002 GT Purchased new, Loaded with options Mud Flaps, Michelin HydroEdge, U-Bend Replacement, GMPP Handling Kit, ZZP Strut Tower Brackets
1991 Porsche 944-S2 with 175,000 Miles (and counting)
eohrnberger is offline   Reply With Quote
Old 07-11-2006, 09:17 PM   #2
eohrnberger
Re: 2000 Safari 70K miles floorboard vibration @ 70-80
Well, I had my shop take a look at the truck to make sure that all the U-joints, drive shaft, etc. etc. was OK, and they all were. Kinda figured that.
But the darn thing still has that vibration, and it's really annoying when going down the highway with the cruise control set at that speed.
Old 07-13-2006, 10:55 PM   #3
old_master
Advisor/Moderator
old_master's Avatar
old_master Normal reputation
First thought was driveline, shifting to neutral usually takes driveline out of the picture if the vibration continues. If the vehicle is equipped with drum brakes on the rear, it's possible that a weight fell off of a drum. A close examination of the drums will determine if this is the case, (the weights are spot welded on at the factory). Excessive toe in or toe out can also cause a vibration that is usually felt in the steering wheel, but can also cause a vibration that is felt on the floor. Run your hands over the inside and outside edges of the shoulder of the tires, it should be a smooth wear pattern. If the pattern is jagged and symetrical, have the alignment checked. Hope this helps.
old_master is offline   Reply With Quote
Bookmarks
Google
Web AF
