Update
blk_srt
07-05-2006, 07:52 PM
Today I did a little work on the talon. Basically just checking the basics. Plugs and wires where in good shape, no holes in the pistons:lol: It has compression, I didnt check it because they wanted $50 for a gauge and I didnt have that much. I did however get a caliper and was going to test cw but damn the car is to low so I need to jack it up to test that. The spark plugs smelled of gas. If I do end up having to pull it, is it easier to pull the motor and trans as a unit or seperatly?
Thor06
07-05-2006, 08:53 PM
Its easier as a whole. Just ask Talon69, he pulled it just the engine, realized what a bitch it was, then pulled the tranny, stuck it on the engine and then put it in the car.
Blackcrow64
07-05-2006, 09:43 PM
Way easier as a whole. When I put mine all back in thats how it'll be goin down.
blk_srt
07-05-2006, 11:06 PM
Ok, Tomorrow I'm going to go out and check for cw, if by chance its not that(crosses fingers that it is for an easy diagnosis) then I guess I'll go get a compression tester and if its not that then I'm stumped. Because honsetly what else would cause stalling, no throttle responce, but perfect running in the high rpm ranges?
Talon69
07-05-2006, 11:13 PM
Oh boy alot easier to pull it all together!!! I pulled the engine by itself but it also took me 4 hours!!! no bullshit i had to do way to much shit.
When i put the engine back in with tranny it only took me like 20 minutes to get it dropped and in place for the mounts ;)
E-Klips
07-06-2006, 08:11 PM
Its way easier to pull it separate. I can have the engine and tranny out in about an hr. Pull the tranny/t-case in less than 45mins and then just 1 motor mount and the engine is out. If you leave the tranny on the block, you still have to disconnect the t-case and axles which is easier to do when you pull the tranny. Then you dont have to worry about tilting the engine/tranny to get it out.
blk_srt
07-07-2006, 12:24 PM
Ok, update time. End play is .020 so she walked. I'm going to go with the stage 2 stroker kit from SBR. I talked to Mark today and he said that kit will handle upwards of 900whp and its only $1499 so I'm pretty excited.
vanilla gorilla
07-07-2006, 01:38 PM
Sweet, not the crank walk but the decision to stroke. What are you going with 2.3?
blk_srt
07-07-2006, 04:25 PM
yeah 2.3. I'll be running a 16g for a while on it to so I'll have some hella bottom end :)
vanilla gorilla
07-07-2006, 04:47 PM
Nice. Will you upgrade your turbo eventually? Your running small 16g right now right? Maybe by the time your ready for a turbo upgrade I will be out of debt and have some extra cash so you can sell me your s16g. :grinyes:
blk_srt
07-07-2006, 05:32 PM
eventually I'm planning on running a gt35 or 40
