Re: Fuse 17 Keeps Blowing -a/c
Does it only blow the fuse if you are using the A/C?
Maybe some of the coolant found its way into the A/C clutch field coil which is normally sealed and shorting it out, or maybe coolant in a connection somewhere is causing the short.
Have you pulled all the A/C-related connections, cleaned them, dried them, and re-installed with the dielectric grease? Unlike pure water, coolant will not evaporate easily so it can stay in connections for a long time. It is water-soluble though show you can use de-ionized water to clean the connections.
-Rod
