Stanza 1992 Oil Leak
I have a 1992 Stanza, it is throwing a lot oil all over the right side of the engine compartment. I have power washed it several times but can't seam to find where it is comming from. I just got done changing the oil pan gasket and it still does it. This time it lookes like it might be comming from above or around the power steering pump but con't see where. When it throws the oil it goes all over inside the fender well, tire, axle, firewall, front of engine, oil pan, etc. All of this started about a month after I had engine out and changed all of the gaskets, seals, hoses and a head job. If I had left it would not have gone this long before it started throwing the oil. It is only at the front of the engine and not the rear (right side of car). Any help would be app.
