Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Racing > Drag Racing
Old 07-03-2006, 12:08 AM   #1
whtaznboi829
whtaznboi829 Normal reputation
Send a message via AIM to whtaznboi829 Send a message via MSN to whtaznboi829
Question Optimum shifting
Is there a formula to shifting to get optimum power?? Like is there a specific rpm that promotes optimum powere in relation to torque or anything of that sort??
whtaznboi829 is offline   Reply With Quote
Old 07-03-2006, 12:16 AM   #2
VR43000GT
VR43000GT's Avatar
VR43000GT +50
Send a message via AIM to VR43000GT
Re: Optimum shifting
Well there are optimum shifting points in every car. Most people drive their car and find the best point to shift. Sometimes its right on your peak hp point in the power band. Often people redline in first since first gear is such a low grear that they just drag it out to the redline that way when they shift they are at a higher rpm when they reach the next gear. After that you kind of just have to due a few test runs and find your best shift points on your own. I know you can buy tachtometers with a light that lights up (I believe you set it up to when you want it to light) when you should shift or even a little before you shift because you have to allow for reaction time.
VR43000GT is offline   Reply With Quote
Old 09-03-2006, 11:29 PM   #3
SpinnerCee
SpinnerCee's Avatar
SpinnerCee Normal reputation
In general you should hold a gear until the HP peak, your shift should cause the RPM to drop to just below the torque peak so the car can continue accelerating.
Obviously, knowing the powerband [HP/TQ] of your engine helps a lot here -- the setup of the car [gearing/trans] should compliment the engine.
The problem with a street trans on the strip is that the gears are not symetrical -- the drop will liekly be quite diffferent with each gear change.
That's why we practice.
SpinnerCee is offline   Reply With Quote
Old 09-20-2006, 03:59 PM   #4
JekylandHyde
AF - Advisor
JekylandHyde's Avatar
JekylandHyde Normal reputation
And the answer is ....
Formula for optimal shift point:
(Lower gear ratio / higher gear ratio) X RPM at peak Torque = Shift RPM
Sponsorship: Amateur Motorsports <-- Get the book! - books are now available for shipment
JekylandHyde is offline   Reply With Quote
Old 11-19-2006, 12:56 PM   #5
ECMgarrett
ECMgarrett Normal reputation
get on a dyno, see where your power is, then go from there
Xfighting the war on drugs a 1/4 mile at a timeX
93 mr2 turbo
94 rodeo
99 buell s3
76 HD shovelhead
ECMgarrett is offline   Reply With Quote
Bookmarks
Google
Web AF
