2001 power steering pump removalscuba4321 07-02-2006, 09:43 PM how hard is it to remove and replace th ps pump on my 2001, 3.0 ? Any tips? 2000mudder 07-03-2006, 08:43 AM it's not that hard. lots of room to get to bolts. did yours go bad? scuba4321 07-03-2006, 01:27 PM well I thought it was the pump, it was squeeking like hell, I hit the back of pully with WD40 and it stopped for a minute. I ended up replacing it this a.m. not that hard. Fired it up and the squeeking it STILL THERE:banghead: I have been :banghead: my head, I have tried alternator, not it, both pulleys, not it, know ps pump,. I checked water pump, is fine, no leaks. I soaked the ac pully and it stopped for about 1 mile. Do you think know the whole compressor needs to be replaced or is there a replacable bearing. Man this is starting to suck 2000mudder 07-04-2006, 02:12 AM i found this stuff at walmart called lube gell. sqirted it in a/c clutch holes and it stopps squeek till it gets wet then it sqeeks again. gonna trade mine in before it starts squeeking again!!!! tried wattery lube's with same luck u had. Automotive Network, Inc., Copyright ©2012
