header problem
97stratus
08-07-2002, 01:47 PM
I had a header put on my car a couple of months ago. Since then I've had it to several garages trying to get it to stop leaking. It has been leaking where it comes together with the catalytic converter and I am running out of ideas. Does anyone have a suggestion on how to get it fixed?
Polygon
08-07-2002, 06:39 PM
Well first off what is it leaking? The only liquid that should ever come out of your exhaust is water from condensation.
97stratus
08-07-2002, 08:19 PM
It is leaking where the header meets the flange. It isn't leaking liquid it is leaking exhaut gases.
Polygon
08-07-2002, 10:52 PM
Oh, hehe, GOOD! Simple, take it to a good muffler shop and have them fix it. What are the places you are taking it to telling you?
911GT2
08-07-2002, 11:48 PM
A solid weld (or much more likely new gaskets) should solve your problem right away.
97stratus
08-08-2002, 01:12 PM
every place i have taken it to says they fixed it and then by the time I get home it is leaking again.
SaabJohan
08-08-2002, 02:52 PM
Maybe you need a better gasket. Can the exhaust pipe expand freely?
97stratus
08-08-2002, 09:10 PM
A gasket will not fix the problem. My header isn't leaking at the block it is leaking at the flange that hooks up to the cat. The flange is a bell style one so there is no gasket. And the problem with welding the leak is if it ever needs to be replaced I will have to cut out the whole section.
911GT2
08-08-2002, 11:49 PM
I realize the welding will severely damage the header in the long run, that's why i never seriously considered it. Have you thought of installing a new flange?
AquaDave
09-07-2002, 10:47 PM
there should be still a gasket for the connection. it should be either a flat gasket shaped liked male end or a doughnut. they also make a liquid exaust sealer put it on before bolting them together. You might just have a bad header. as said before welding might be your only option.
Are you sure it's leaking? or are you hearing "header ping".
