How to remove the head lamp assembly?
Hi,
I have a 2001 Passat, manual transmission. I've had some trouble with the drivers side headlight and discovered that the connector the headlamp plugs into has melted. I tried finding a replacement connector but they are not available, as far as I can tell. So I broke down and bought a new wiring harness but I now see that it is internal to the headlight assembly.
Now I'm trying to figure out how to remove the headlight assembly so I can get inside and replace the harness. I found three screws on the top that I removed and that made the assembly loose but I couldn't get it out of the car. It moved around more than half an inch but that was it. Any suggestions? Does anyone have a picture of the assembly details for that part of the car?
Thanks in advance,
Linn
