"Service 4WD"jas45 06-29-2006, 04:46 PM Hi, own a 99 Jimmy. My "Service 4WD" light came on yesterday. I have no indicator light lit for selector, normally lit for 2 hi. Swapped friends working dash selector switch with no change. Checked fuses and all OK. Any help? Thanks in advance. MT-2500 07-01-2006, 06:49 PM Hi, own a 99 Jimmy. My "Service 4WD" light came on yesterday. I have no indicator light lit for selector, normally lit for 2 hi. Swapped friends working dash selector switch with no change. Checked fuses and all OK. Any help? Thanks in advance. What engine and transfer case? I would have another look at all fuses. If it is getting power and ground go for a scanner code test. Mt jas45 07-01-2006, 07:56 PM 4.3 Vortex engine not sure on transfer case. Since posting I've done about ten trips of which the lght has been on seven of the ten trips. Thinking a faulty sensor?? MT-2500 07-01-2006, 10:42 PM 4.3 Vortex engine not sure on transfer case. Since posting I've done about ten trips of which the lght has been on seven of the ten trips. Thinking a faulty sensor?? A good scanner check will tell the story. Post back codes. MT Automotive Network, Inc., Copyright ©2012
