Re: HELP!! Pinging Engine!
The bad gas scenario seems likely.
Also, if you have a steady hand and some brake and electric parts cleaner, or just electric parts cleaner, and a cotton swab, you should be able to clean the sensors of the MAF sensor that way2old mentioned. Oh, you will also need a T-15 or T-20 Torx bit to get the elements out of the MAF housing. Wet the cotton swab with the cleaner and very gently clean the sensor elements. You will notice that the wires for the elements are very small (ie: not real strong) so you will definitely want to be somewhere where you won't get startled or bumped.
If you don't break the elements, you won't hurt anything, and there's a good chance your fuel economy will improve afterwards.
-Rod
