Need Help Please
Google
Web AF
230
08-06-2002, 06:19 PM
While mounting my clear corners on my 230 this morning, I made the biggest F****** mistake!!! Being the dumbass that I am I decided to use caulk to set the lenses so that they were not loose. Well it just so happens that the caulk I was using was white and seeped through a gap and is now unpleasantly showing through my clear corner.
I got as much out by removing it and scrubbing with water and soap but there is a thin strip that I cannot get to because the gap is to small to fit anything into (including bristles, a razor, paper towel, ect...). So my question is: Is there a solution that I might be able to soak the lens in that could dislodge the caulk then blast out with an air compressor? Any help would be greatly appreciated.
Thanks,
Distraught Matt
By the way the caulk I used is silicone based if it makes a difference
Google
Web AF
