Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Mazda > Nonspecific
Old 06-27-2006, 12:33 PM   #1
Misipislim
Misipislim Normal reputation
Painting Miata Parts
I have removed the plastic nosecone and rear license plate area on my 1996 Miata. I have sanded progressively to 400 grit. I do not plan to prime.
Should I sand to a finer grit for adhestion?
How long between coats do I wait before I sand again and what grit sandpaper should I use? Wet or dry.
Is sanding necessary between final & clear coat?
Thanks
Misipislim is offline   Reply With Quote
Old 12-11-2006, 01:18 PM   #2
skibear
skibear Normal reputation
Re: Painting Miata Parts
Sanding with 400 wet-sand is fine. Would recommend an adhesion promoter be applied before color though, then spray color to match (let coats dry to "finger touch" between coats) then apply clear. No sanding between color and clear, maybe "tack- cloth" off but only if not metallic since you could otherwise "drag" the metallics and that would definitely show. Let clear dry to touch between coats,(usually 2-3 coats). If you have access to a heated booth that would be great but if spraying "outside" plan accordingly with temp and longer dry times. Patience is the key thing here! Good luck!
skibear is offline   Reply With Quote
Bookmarks
Google
Web AF
