what size gears do a 2.7L 95.5 toyota tacoma have??jbutts 06-26-2006, 10:11 PM i got a 95.5 toyota tacoma. its 2.7L 4X4 Auto and im not sure what kind of gears it has in it. i put a 6 in lift with 33 in tires and i need a little more power and the trans needs some help and i was wondering what size gears i should put in it and what brand is a good one. thanks for the help. TcmaBoy 06-26-2006, 10:31 PM Here is a chart for the axle codes and a link to a gear chart. There should be a tag in the drivers side door jam. Find your gears and match them up for an exact match. I would reccomend a 4.56 or a 4.88 if you wheel it. http://www.tacomaterritory.com/wiki/index.php/Gear_Codes http://www.tacomaterritory.com/wiki/index.php/Gear_Chart Flash75 06-27-2006, 07:44 AM Here is another link with information about how to identify your vehicles gear ratio. Within this article are additional links about gearing http://www.brian894x4.com/Gearratiosanddiffs.html Clifton jbutts 06-27-2006, 03:40 PM What brand of gears would you recommend for my truck. None too expensive but some that will last and do the trick. thanks for yalls help TcmaBoy 06-27-2006, 04:25 PM Yukon gears. Be prepared regear is not cheap. You will need to buy master install kits for both diffs. Brian R. 07-08-2006, 09:55 PM If you guys have links to important truck data like the above, please give me the links so that I may post them in the FAQ thread. Also, see if you can determine if any particular information also applies to 4Runners, Tundras, T100, Older pick-ups, Land Cruisers, etc. Thanks vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
