Go to the prats store and get some rubber hose that has the same inside diameter as the tubings outside diameter and also get four small hose clamps. Cut a piece of hose about two inches more than what you need to fill in where you cut the twisted leaking tubing out. Now take a rough file and file the tubing and make it rough on the outside so the hose won't slip off easily and flare the tubing ends just a tad and that will make it more dificult for the hose to slip off.
Clean the tubing good and take the hose and slip it over the tubing one inch on each end. Don't use any lubricant that will make the hose slip on easier. Take two small clamps on each end about 1/4" apart and screw them down nice and snug. Don't over tighten them and snug enough is when you see the rubber start poking thru the slots in the clamps just a little bit. Let it sit about fifteen minutes so the hose can 'seat' on the tubing, then crank 'er up and watch for leaks. If it leaks tighten the clamp just enough to stop the leak, do not overtighten it. That should hold a long time because the pressure in the lines isn't that much.
I say 'not much pressure' because when you install a transmission cooler you cut the tubing and put a rubber hose on the tubing that goes to the cooler. Virtually the same thing I told you to do, so do it that way and you probably won't have to replace the tubing, leave the hose on and let 'er dig.
Tell the guy at the parts store what you want to do and he should be able to fix you up with what you need and take a piece of the tubing with you so they can get the exact size ID hose you need. ID = Inside diameter. OD = Outside diameter.
If you insist on metal tubing, I think most tranny shops can fabricate the right tubing with the right turns, twists and fittings, so call a few tranny shops and also ask at the auto parts stores.
