Automotive Forums .com - the leading automotive community online! Visit IgorSushko.com and see what it's like racing in Japan
Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Toyota > Camry/Camry Hybrid/Vista
Old 06-25-2006, 08:06 PM   #1
DJPsystems
DJPsystems Normal reputation
transmission whine, 92 Camry V6
I am thinking of buying this car, it runs great but it makes a whining noise that is consistant with the engine rpm. It makes the noise in drive and reverse, but it goes away when it is in park or neutral. Fluid level looks ok. The car has 144000 miles. Any ideas?
DJPsystems is offline   Reply With Quote
Old 06-27-2006, 09:53 AM   #2
idmetro
idmetro Normal reputation
Re: transmission whine, 92 Camry V6
Does the fluid smell burnt? I'm afraid I'd have to assume the transmission is not well and plan on a replacement, I'm sure Toyota didn't plan on their being a whine in the transmission so I'd make an offer on the car assuming a transmission replacement was needed. If you get it and discover it was something less severe then you are ahead of the game, if you get it and the trans goes south at least you weren't surprised. If you get the car, the first thing I would do is a trans fluid and filter change and see if that makes any difference. My 91 is very sensitive to the fluid level, I also changed over to Mobil 1 ATF and noticed a significant improvement (much smoother shifts).
idmetro is offline   Reply With Quote
Old 06-27-2006, 07:04 PM   #3
xxsicpuppyxx
xxsicpuppyxx Normal reputation
Same here, DJPsystems... Only at stop lights is when I get the whinning noise. RPMs slighty go up and down. Happenes about 50% of the time while on the road. I should do a transmision flush, see if that helps... but other than that, the car runs amazing....
xxsicpuppyxx is offline   Reply With Quote
Old 06-28-2006, 10:45 AM   #4
Toysrme
AF - Advisor
Toysrme's Avatar
Toysrme Normal reputation
Send a message via ICQ to Toysrme Send a message via AIM to Toysrme Send a message via Yahoo to Toysrme
Cool Re: transmission whine, 92 Camry V6
Change the differential fluid.
Flush the transmission.
Toysrme257th - AIM about anything, anytime; including v6 turbos.
World's second ES 300/3vz-fe Turbo.
Toysrme is offline   Reply With Quote
Old 06-28-2006, 01:43 PM   #5
idmetro
Excellent advice. Not all who read this may know that the differential and transmission are part of the same assembly but have separate fluid reservoirs and will require separate drain/fills. I have heard of instances where the transmission was religiously maintained but the differential was not leading to failure.
Old 07-04-2006, 08:46 PM   #6
DJPsystems
I flushed the trans and I threw in a bottle of lucas but the noise is still there. The trans appears to be shifting normal. Also in the manual that I have it says that the 92-93 have the same reservoir for the trans and differental. Is this correct?
92 300ES
00 Sable DOHC duratec
86 Camaro Z28
Old 07-05-2006, 11:26 PM   #7
Toysrme
AF - Advisor
Toysrme's Avatar
Don't use lucas. It's horrible.
Addatives in a transmission are a huge no-no. Transmission fluid is suppose to have a certain friction for the clutches to work. Addatives change this friction.
Lucas also introduces ungodly amounts of air into oils.
http://www.bobistheoilguy.com/images/lucas/lucas.htm
Normal oil
Oil with air
Yikes. A torque convertor would own lucas hardcore.
Now flush the fluid.
Have you changed the differential oil yet? it uses the same Dexron III ATF.
Bookmarks
Google
Web AF
