Aiming Headlights?m3kidds 08-05-2002, 11:37 AM i just put on clear headlights on my 97 civic and was wondering how to adjust the headlights? i see 2 screws but one is almost impossible to turn in the location it is in. any tricks? thanks Tominos 08-06-2002, 12:32 AM should be 2 screws that are very easy to turn with a philips screwdriver. the screw is connected a gear, that turns a nother gear. may be a little hard to find i guess, but theres only two and you'll see that you're supposed to stick a long screwdriver in the hole. m3kidds 08-06-2002, 11:15 PM ok .. i see the screws but the one on the drivers side is almost impossible to get to.. is there a way i can do it without removing the light? Tominos 08-06-2002, 11:39 PM you're not supposed to take off headlights when aiming them, i think you are looking at the wrong part.look at it from top, you see a level inside the headlight. then i think on the side if you look at top but 45 degrees to the left or right depending on headlight. there shouldn't be anything in the way, i just did it about a month ago in my autoshop took all of 1 minute to do. just need a long screwdriver and make sure you do it on level ground. OG20 08-21-2002, 04:23 AM i was just wondering if anyone knows how to aim the headlamps for the jdm integra conversion, other than physically moving the whole unit... is there supposed to be an adjustor screw or something?... any ideas? websites? diagrams? anything will help... thanks NuEra 08-28-2002, 01:06 AM I was just tryin to aim my headlights the other day too, but it looked like the verticle adjustment wasnt working because the bubble didnt move. Do you have to turn an incredibly long time or have my headlights been in the oven to many times? m3kidds 08-28-2002, 11:44 AM i finally figured out how to aim them.. and yeh i had to turn the screw quite a bit to get the aiming right.. i think you should forget about the bubbles and just do the aiming in a dark area or at night with your lights on so that you can see exactly where you want them to aim. Automotive Network, Inc., Copyright ©2012
