Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Honda > N2O/Turbo/Superchargers
N2O/Turbo/Superchargers Tech forum to assist in Honda/Acura Performance.
Old 06-23-2006, 06:25 AM   #1
Shinji
Shinji Normal reputation
BOV Install
Hello everyone,
Well I finally got the new Turbo back from Greddy (Sent it back 3 times only to find out there was a machining issue in the housing.) and it works great however I was looking at my intake pipe near the throttle body and realized there is no place for a BOV install.
Now obvious I am going to need one if I am going to protect my investment a little more then what the wastegate does.
From what I have read both here and other place's all I need to do it tig weild the flange into the intake pipe going to my throttle body and drill a hole correct?
Now also I am not sure where I can T into for a Vacuum line to connect to the BOV or if there is a certain vacuum line I can use.
I am installing this on a 99 Honda Civic EX (D16Y8), any help would be great as google searching has so far not really explained anything for a Civic.
I did find that Eclispe install directions helpful for a "general" installation location.
Thanks in advance.
Shinji is offline   Reply With Quote
Old 06-23-2006, 08:41 AM   #2
Schister66
AF -Advisor
Schister66's Avatar
Schister66 Normal reputation
Send a message via AIM to Schister66 Send a message via MSN to Schister66
Re: BOV Install
cut the vaccuum line to the brake booster before the backflow valve and T off of that for the vaccuum lines for the BOV and WG. Get a shop to weld on the BOV flange so that you have a good seal unless you're a good welder.
The new build is underway...
Borg Warner S256 + 9.8:1 built GSR + E85 = 450whp Daily Driver
Schister66 is offline   Reply With Quote
Old 06-23-2006, 11:29 PM   #3
Shinji
Re: BOV Install
Yea the welding is a peice of cake just wasn't sure if I could T into the same vacuum line or not.
Thanks.
Bookmarks
Google
Web AF
