ive got a prob with my four door tacoma's doors squeaking-- i cant figure out where its coming from and ive put silicone lube. on the door hinges.. any ideas or something thatll make it stop?
All you can really do is lube up the hinges. Try using a spray lubricant with teflon. It will penatrate into the hinge and form a film when it dries.
They do get squeakey with age. You can try loosening the hinges and realigning the doors. Sometimes the body tweaks a bit and the hinges get misaligned. They end up binding a bit causing the squeak.
