Re: 97 Astro gear shift issue
If the service engine light is not on i.e. no code, it's a physical problem with the trans. The pressure is building too slow from first to second. could be a sticking valve, could be a bad seal, could be the valve body is warping.
On another note have you checked the trans fluid level lately? Do this with the engine warm and running. Filter might be clogged up as well.
'89 Astro 4.3L Z
CFM-Tech power plate
2.5" exhaust, Low restriction cat and muffler
Jet stage I chip
B&M trans cooler
'96 Jeep Cherokee
'99 Chevy Cavalier
