2006 Mercedes-Benz SLK 55 AMG Special Seriesp4el 06-22-2006, 03:46 PM Affalterbach, Jun 09, 2006-Mercedes AMG has developed an exclusive and distinctly puristic special series SLK. With the AMG 5.5-litre V8 engine enhanced to 294 kW/400 hp and 520 Newton metres, numerous lightweight construction components, carbon hardtop, 19-inch AMG forged wheels, AMG height-adjustable torsion sports suspension and AMG high-performance composite brake system the special SLK 55 AMG demonstrates even more convincingly its sports talent. Wide, stocky and low slung - the first impression already makes it clear that the SLK 55 AMG is something very special. The front of the car has a restyled AMG front apron with large air intakes which supply the additional transmission oil cooler and the high-performance steering gear oil cooler with sufficient fresh air. New side air outlets of black carbon ensure an effective flow through of the larger engine oil cooler. The front fenders which are now wider are made of the ultra-light carbon-fibre-reinforced-plastic (CRP) and have black out-lined air outlets. The non-retractable hardtop of the two-seater is also made of CRP; the black central part with carbon fibre structure provides attractive optical effects. Dis-carding of the vario roof and the complete roof hydraulics has not only enabled a lowering of the centre of gravity, but has also resulted in a notable reduction of weight - the puristic special series of the SLK 55 AMG is with a curb weight of 1,495 kg according to EC standard 45 kg lighter than the basic vehicle. This means that the power/weight ratio has improved from 4.3 to 3.7 kg/hp. See more herehttp://thestyleblog.com/?p=93 Automotive Network, Inc., Copyright ©2012
