Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Honda > CL/Inspire/Saber/TL
Old 06-21-2006, 01:11 PM   #1
hydroguru
hydroguru Normal reputation
Engine Stutter
I have a 2003 TL-S. Runs fine most of the time. Every so often, while cruising at a constant speed, does matter what speed, the rpm's start fluctuating and engine looses power. Kind of stumbleing. As soon as I hit the gas, the rpms stablize and the engine returns to normal.
Does it when wet, when dry, cold or warm.
Anybody have any ideas? Thanks.
hydroguru is offline   Reply With Quote
Old 06-25-2006, 05:54 PM   #2
AcuraTL2005
AcuraTL2005's Avatar
AcuraTL2005 Normal reputation
Re: Engine Stutter
i take it you mean "Doesn't Matter what speed" but if you at a cruise...could be an IAC problem, a vacuum leak wouldn't make a diffrence off idle, unless this was a big vauum leak, in that case im pretty sure you would hear it...and it would stall at idle, no CEL illuminated??
Stop Cyrin, Start Tryin
AcuraTL2005 is offline   Reply With Quote
Old 06-26-2006, 07:46 AM   #3
hydroguru
Re: Engine Stutter
Yeah, meant 'doesn't matter what speed'. I haven't noticed anything like a vacuum leak under the hood and idle runs just fine. No check engine light. Can you define IAC? Ignition coil?
It happens normally when I am at constant throttle position. The power fades and the rpm's begin to droop. The tach will jump a little and the longer I let it go, the more the power drops. But as soon as I hit the throttle the system stableizes.
Could it be the throttle position sensor?
Appreciate the help.
Old 06-26-2006, 10:32 AM   #4
AcuraTL2005
Re: Engine Stutter
IAC = Idle Air Control, even though your off idle...your IAC Opens up to around 100%, sometimes if it doesn't open you can feel a slight sputter. It could be your TPS, you can always check it before gettin to indepth.
Bookmarks
Google
Web AF
