Originally posted by BANNED
no quite a few things about the body design, interior, and suspension are WAY different.
Also.. does this sound like your regular accord?
SPECIFICATIONS:
Engine: Inline 4cyl, 2157cc DOHC VTEC
Max HP: 209HP @ 7200 RPM
Max Torque: 159 lb ft @ 6700 RPM
Top Speed: 142MPH
0-60 MPH: 7.7 sec.
MOTOR:
- Cylinders: In-line 4
- Displacement: 2157cc
- Bore/Stroke: 87x90.7mm
- Compression Ratio: 11:1
- Maximum Power: 217 HP @ 7200 RPM
- HP/liter: 99.67
- Torque: 159 lb ft @ 6700 RPM
- Fuel system type: MPFI
- Distribution: Double Over Head Cam (DOHC)
- Valves per cylinder: 4
- Ignition: electronic
TRANSMISSION:
- Clutch: Monodisc dry
- Gear box: 5 speed manual
- Ratios:
I- 3.285:1
II- 2.090:1
III- 1.481:1
IV- 1.071:1
V- 0.870:1
F- 3.000:1
- Traction: front wheel drive
SUSPENSION:
- Front: Double wishbone, telescopic shocks & stabilizer bar
- Rear: Multilink, telescopic shocks, helicodial springs & stabilizer bar
STEERING:
- Steering wheel turns: 3
- Turning diameter: 10.8m
BRAKES:
- Front/diameter: ventilated disc 300mm
- Rear/diameter: disc 260mm
WHEELS:
- Rims: alloy 17"x7
- Tires: 215/45ZR 17 Michellin
PRICE (Europe): $33,450 US (estimated)
