Steering issue...skibum1111 06-20-2006, 06:08 PM OK here's the issue: When on a ramp and I get on the gas, the car starts to straighten out while cornering. Recently started doing this, and I can hear things moving around. Motor mounts are good, cv shafts, bearings, tie rod ends, ball joints, brakes, tires are all good as well as the struts. It's definately a front end issue, anyone have any ideas? It's a 95 gt quad. Thanks. xeroinfinity 06-20-2006, 06:54 PM lower control are bushings :dunno: (just a guess) skibum1111 06-21-2006, 04:15 PM I wish it was something that simple. Pulled one of the axle shafts out today, oil that came out with it was silver..... Metal in the transmission :banghead:. Guess I need to start searching for a new trans. Anyone out there ever rebuild a fwd trans? I've done rwd before, how hard is the differential? xeroinfinity 06-22-2006, 12:22 AM its different, need some different tools also. I dont hav them, but I hav a 4t45e toredown now trying to get performance clutchs. Yours is a manual isnt it? It should be easy if you hav done a rwd manual before. Autos either way can be intimidating sometimes, especially if you for get what goes where :eek: skibum1111 06-22-2006, 08:29 PM I got lucky with it today, found a used trans for $100. Called the local trans shop to price changing the pinion and ring gears, they tried to sell me a used trans for $950, would not give me a price to change the gears. Guess I'm changing the trans, then going to tear down the old one to see exactly what happened. Automotive Network, Inc., Copyright ©2012
