'94 toyota pickup gauges not workingmetafizx 06-19-2006, 07:20 PM hi, my dash gauges just recently quit working (fuel/temp/speed). Fuse is ok (changed it just in case). they came on once and then quit again. any ideas out there ? thank you in advance :dunno: KimMG 06-19-2006, 08:36 PM Time to get a wiring diagram, meter, and physically trace the circuit. Check to make sure you don't have any loose or corroded connections in the dash. metafizx 06-19-2006, 10:39 PM ok, I was dreading that answer...but I think you are right on the money. metafizx 06-20-2006, 01:58 PM after breaking the dash, I found the broken ground wire. fixed that, and now the gauges work. supergluing the dash back together. I guess it got brittle from sun damage over the years. oh well, can't have everything perfect. :banghead: KimMG 06-20-2006, 08:49 PM Thanks for letting us know how it went. Try a local pull your own part for replacement dash pieces if the glue doesn't work. Automotive Network, Inc., Copyright ©2012
