Which GA GT is the fastest? 1st,2nd,3rd?
spoolinmonkey
06-19-2006, 01:28 AM
:banghead:basically i want to know which ga gt is the fastest stock from the factory? The newer ram-air style gt is the fastest isnt it? they have like 175hp an extra 5 oposed to the non ram-air gt 170hp. I also would like to know what rpm the engine shifts at when your tromp on it? is it right at the redline? What are they governed at, 110mph? How easy is it to lift the governer. Aswell as gow do the ga's in general respond to mods eg...cai, exhuast .......I have a 91 talon tsi and it has no cat or resinators, can i do it with a ga, or does it have all that oxygen sensor crap to worry about? stock 0-60 1/4m specs would also be useful thanx alot guys....
Gir-_-
06-19-2006, 07:54 AM
Every GA GT(v6) is 175HP stock (RAM Air, different transmission ratios for shifting 'same stock shift points I think' and better handling) You have the GT and the GT1 trim options
The GA SE(v6) is 170 Stock (not to big of a difference, different ratios as from the GT 'GT being better', handling is good but dunno if its up to GT standard but like most cars can be fitted with struts, strut bars, lowering springs... theres only really trim level difference ... the SE and the SE2.. Same stock 170HP)
Most aftermarket parts for any grand am will fit either a GT or SE so its really not to much of a difference except for the transmission ratios being slightly different.
So if you can pick up a GT, but likewise an SE is just as great just not as good around cornors I would think ... well mine isnt =) More of a straight forward car. (drag-n-such, or 40,50,60 rolls)
Going from a stop in a stock Grand AM isnt exactly all too good for the auto trans :nono:
Auto Consumer Guide - 1999-2005 Grand AM SE/GT Info/Specs (http://www.auto.consumerguide.com/Auto/Used/reviews/full/index.cfm/id/2397/act/usedcarreviewspecs/)
Check it out
