'95 Tacoma overheatingmsaga79 06-18-2006, 04:11 PM I replaced my water pump and my thermostat and the truck works great except for when I go up hill. Everytime I go up hill the car overheats. I would appreciate any ideas that anyone might have. Thanks! Flash75 06-18-2006, 07:39 PM Check the radiator or have it checked at a radiator shop. It's 11 years old and probably partially clogged up. Water pumps may leak or make noise but they rarely cause overheating. Clifton msaga79 06-19-2006, 12:31 AM Thanks! Will try. bangbg 06-20-2006, 12:22 PM Check the radiator or have it checked at a radiator shop. It's 11 years old and probably partially clogged up. Water pumps may leak or make noise but they rarely cause overheating. Clifton Good advice! At 225,000 my 2000 Tacoma started overheating and I ended up replacing the radiator. The dealer told me it was worn out. I asked him if they can't boil it out like they used to in the old days? He said no not with these newer radiators, they just wear out. Dealer charged $700.00 for the labor, new radiator and cooling system flush. That radiator started leaking 13 months later, the Toyota warranty was 12 months and they wouldn't give me anything towards another replacement. I got a new Modine radiator from NAPA for $250.00 that has a lifetime warranty and put it in myself. BTW- if you have a Prerunner 2WD then the radiator is the 4WD model, not the 2WD. vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
