Rodeo02 - need your help in regards
Ramblin Fever
06-15-2006, 02:15 AM
to the Trailblazer. As you know, my sister has an '02 TB that she bought used, we can not find the part needed to lower her spare tire - I'm guessing it's a crank type set-up?
Can you post a pic of the part she's obviously missing out of her TB. I don't have anything around that will lower it, and we can't check the air pressure as some idiot mounted the tire stem-side up. :banghead:
rodeo02
06-15-2006, 08:59 AM
Yep it sure is. It's the same crank setup that the under-mount spare tire rodeos have. All the gear should be mounted under the pass side rear seat pan. For the tire winch, it's just a slotted type receiver. A long flat bladed screw driver will suffice. If she's never had the spare down, the winch is probably seized up. Very common occurance on these setups. If that's the case, the cable has to be cut at the wheel hub and the winch unit can be removed and replaced.
G/luck
Joel
rodeo02
06-15-2006, 09:20 AM
Ramblin, here's a good place to poke around for TB related stuff: http://forums.trailvoy.com/showthread.php?t=6571&highlight=spare+tire (see if u can find me there!:lol: )
Just in case: http://cgi.ebay.com/ebaymotors/SPARE-TIRE-CARRIER-02-TRAILBLAZER-ENVOY-N-I-B-15247311_W0QQcmdZViewItemQQcategoryZ33746QQitemZ80 74965831QQrdZ1QQsspagenameZWD1V
G/luck
Joel
Ramblin Fever
06-15-2006, 10:48 AM
Thanks a bunch! Don't have the crank set-up on my Rodeo, it's on the tailgate. In fact, her TB is the first crank-set up I've dealt with - thanks!
