General infoblazee 04-29-2006, 12:29 PM Error Codes On Gm Radios What Do They Mean? Info thanks to Flatrater (http://www.automotiveforums.com/vbulletin/member.php?u=68974) Cassette Errors E10 : Tight tape error Cause(s): A restricted cassette tape transport or broken cassette drive belt Correction: Substitute a different cassette tape. If there still is an error code, service the unit at an ACDelco® Service Center. E11 : Broken Tape Error Cause(s): A broken cassette tape Correction(s): Substitute a different cassette tape E12 : Communication Error Cause(s): A vehicle/radio communication problem or an internal radio communication problem Correction(s): Disconnect the battery voltage to the radio then reconnect after a few minutes. If there still is an error, service the unit at an ACDelco® Service Center. E13 : Tape Communication Error Cause(s): The micro-processor is reading the speed pulses from the tape deck either too fast or too slow. Correction(s): It the tape player is still playing a cassette, try a new cassette. If there is still an error, service the unit at an ACDelco® Service Center. E14 : Wrapped Tape Cause(s): The tape is wrapped around the capstan. This means a tape is wound up in the tape player. This error message could appear when a CD adapter is being used. Other causes could be old or damaged tapes. Long playing (90 or 120 minute) tapes are thin and can stretch easily creating this condition. Correction(s): Try playing a known good quality tape. Remove the CD adapter. C ln Tape Indicator Cause(s): This message appears after 50 hours of accumulated tape play. Correction(s): We suggest cleaning the tape head. Then reset the radio by depressing the eject button for five seconds. Cleaning the heads will not reset the "Cln" display. To reset the "Cln" display, push and hold the eject button for five seconds. The display will return to its normal display. CD Errors E20 : Focus Error Cause(s): The CD player cannot focus on the disc or there is an internal focus problem. Correction(s): Try cleaning the disc or using a new disc. Make sure the disc is loaded correctly. The road could be too rough or there is too much humidity. If the problem is not corrected, service the unit at an ACDelco® Service Center. E21 : Tracking Error Cause(s): There is a problem with reading the disc Correction(s): Try cleaning the disc or using a new disc. Make sure the disc is loaded correctly. The road could be too rough or there is too much humidity. If there is still an error, service the unit at an ACDelco® Service Center. E22 : Motor Error Cause(s): The CD motor is not handling the compact disc properly. Correction(s): Service or exchange the unit at an ACDelco® Service Center. E23 : Communications Error Cause(s): There is a vehicle/radio communication problem or an internal radio communication problem. Correction(s): Disconnect battery voltage to the radio and then reconnect after a few minutes. If there is still an error, send the unit to an ACDelco® Service Center. LLAI CD Changer Errors E30 : Focus Error Cause(s): The CD player cannot focus on the disc or there is an internal focus problem. Correction(s): Try cleaning the disc or using a new disc. Make sure the disc is loaded correctly. The road could be too rough or there is too much humidity. If there is still an error, service the unit at an ACDelco® Service Center. E31 : Tracking Error Cause(s): There is a problem with reading the disc. Correction(s): Try cleaning the disc or try using a new disc. Make sure the disc is loaded correctly. The road could be too rough or there is too much humidity. If there is still an error, service the unit at an ACDelco® Service Center. E32 : Motor Error Cause(s): The CD motor is not handling the compact disc properly or defective magazine mounting screws are interfering with the mechanism. Correction(s): Reload the magazine. If there is still a problem, replace the magazine. If the problem continues, back out the mounting screws. If the condition is corrected, replace the screws with shorter screws or add washers to the existing screws. If this condition still exists, service the unit at an ACDelco® Service Center. E33 : CD Changer Communication Error Cause(s): There is a vehicle/radio communication problem or internal radio communication problem. Correction(s): Disconnect battery voltage to the radio and then reconnect after a few minutes. If there is still an error, determine if the problem is with the radio, the harness or the changer. Inspect for correct voltage at all connectors. If there is still an error, service the unit at an ACDelco® Service Center. E34 : Changer Door Open E35 : Changer Magazine Empty FMI 10-Disc Changer Errors E01 Cause: This indicates a malfunction of the disc changer functions. Correction: Before sending the unit in for service, perform the following procedure: Press the reset button on both the changer and the remote. The reset button on the changer is located on the front panel of the unit. It can be activated with the tip of a pin. If the unit does not operate after resetting it, remove the magazine by inserting a business card between the magazine and the mechanism. The lock lever will disengage to allow the magazine to eject. Make sure all CDs are in the magazine and none remain lodged in the carriage. If, upon removing the magazine, a CD is found lodged in the carriage, remove all CDs from the magazine and reinsert the magazine into the changer. Press the eject button. This should cause the lodged CD to move from the carriage into the empty magazine. The magazine should automatically eject and normal operation will return. If the changer fails to resume normal operation, send the unit to an ACDelco® Service Center. E30 Cause: Excessive temperature Correction: Let the temperature of the changer resume to the normal range. blazee 04-29-2006, 12:40 PM Mechanics Dictonary Info thanks to Flatrater (http://www.automotiveforums.com/vbulletin/member.php?u=68974). Here is a list of different modules in GM cars and trucks and their abbreviations Module- Module Description ABS- Antilock Brake Traction Control ACC -Adaptive Cruise Control with Alert ADG -Accommodated Device Gateway AHLL -Automatic Head Lamp Leveling AHS -Auxiliary Heating System AMP -Amplifier APC -Auto Personal Computer ARS -Antenna Reception System ATC -Active Transfer Case BCM -Body Control Module CCP -Climate Control Panel CDS -Compact Disc CDX -Multiple Compact Disc Changer CHIME -Chime CID -Color Information Display CIM -Column Integration Module CLM -Column Locking Module CMM -Column Memory Module DAB -Digital Audio Broadcast DDM -Driver Door Module DDS -Driver Door Switch DIC -Driver Information Center DIM -Dash Integration Module DPM -Driver Position Module DSM -Driver Seat Module EBCM -Electronic Brake Control Module ECC -Electronic Climate Control ECM -Engine Control Module EKM -EasyKey Module EPS -Electric Power Steering FICM -Fuel Injector Control Module FTC -Folding Top Controller GID -Graphics Information Display HCM -Heating, Ventilation, Air Conditioning Control Module HEMC -Hybrid Electric Motor Controller HUD -Head Up Display HVAC -Heating, Ventilation, Air Conditioning ICC -Integrated Chassis Control IPC -Instrument Panel Cluster IPM -Instrument Panel Integration Module IRC -Integrated Radio Chassis LDS -Left Detection System LGM -Lift Gate Module LMD -Left Middle Door Module LRD -Left Rear Door Module MCS -Mobile Communication System MDS -Mini Disc MDX -Mini Disc Changer MMM -Memory Mirror Module MRM -Moveable Roof Module (Hardtop) MSM -Memory Seat Module NAV -Navigation NDH -Navigation Display Head NRC -Navigation Radio TMS/ONS -Telematic System/Onstar PAS -Parking Assistance PBA -Park Brake Assist PCM -Powertrain Control Module PDM -Passenger Door Module PDS -Passenger Door Switch PHN -Phone PSM -Passenger Seat Module RAD -Radio RAHVAC -Rear Auxiliary Heating, Ventilation, Air Conditioning RCC -Rear Climate Control RDS -Right Detection System REC -Rear Electrical Center RFA -Remote Function Actuation RIM -Rear Integration Module RMD -Rear Middle Door Module RRD -Right Rear Door Module RSA/HVAC -Rear Seat Audio / Rear Heating, Ventilation, Air Conditioning RSD -Right Side Detection RSM -Rear Seat Module RTD -Real Time Damping SBBC -Smart Brake Booster Controller SCM -Seat Control Module SDARS -Sattelite Digital Audio Reception System SDG -Serial Data Gateway SDM -Sensing Diagnostic Module (Supplemental Inflatable Restraints) SIC -Secondary Information Center SODM -Side Object Detection Module - Left SODM -Side Object Detection Module - Right TCCM -Transfer Case Control Module TCM -Transmission Control Module TMS -Telematic System TTM -Tilt Telescoping Module TVM -Television Module UEC -Underhood Electrical Center VCM -Vehicle Control Module VCU -Vehicle Control Unit (OnStar) VIM -Vehicle Immobilizer Module VIU -Vehicle Interface Unit (OnStar) VTD -Vehicle Theft Deterrent Abbreviations and Meanings TERM in - followed by DEFINITION Abbreviation Meaning # 2WS- Two-Wheel Steer 3GR- Third Gear 4GR- Fourth Gear 4WAL- Four Wheel Anti-Lock 4WD- Four Wheel Drive 4WS- Four Wheel Steer A A-Ampere(s) AAT- Ambient Air Temperature ABS-Antilock Brake System A/C-Air Conditioning AC-Alternating Current accel- Acceleration accum- Accumulator ACC- Adaptive Cruise Control ACC-Accessory, Automatic Climate Control Accy- Accessory ACL-Air Cleaner ACM- Air Conditioning Module ACR4-Air Conditioning Refrigerant, Recovery, Recycling, Recharging act- Actual actv- Activate AD-Automatic Disconnect A/D-Analog to Digital ADL-Automatic Door Lock AD- Accommodated Device adapt- Adaptive adapts- Adaptors(ers) ADG- Accommodated Device Gateway adj- Adjust ADL- Automatic Door Lock ADS- Auxiliary Discriminating Sensor A/F-Air/Fuel Ratio AFECM- Alternate Fuel Engine Control Module AFO- Alternate Fuel Operation aft- After AH-Active Handling AHLD- Automatic Headlamp Leveling Device ahrs- Amp Hours AIR-Secondary Air Injection ALC-Automatic Level Control, Automatic Lamp Control AIR- Secondary Air Injection ALC- Automatic Lamp Control, Automatic Level Control ALDL- Assembly Line Diagnostic Link ALM- Automatic Level Control, Adaptive Learn Matrix Alt- Alternative AM- Amplitude Modulation AM/FM-Amplitude Modulation/Frequency Modulation amp- Amplifier amps- Amperages Ant-Antenna AP-Accelerator Pedal APCM-Accessory Power Control Module API-American Petroleum Institute APP-Accelerator Pedal Position Appl- Application APT-Adjustable Part Throttle ARS- Adaptive Receptive System asm- Assembly ASM- Alarm Siren Module ASM-Assembly, Accelerator and Servo Control Module ASR-Acceleration Slip Regulation A/T-Automatic Transmission/Transaxle ATC-Automatic Transfer Case, Automatic Temperature Control ATDC-After Top Dead Center ATF- Automatic Transmission Fluid ATSLC-Automatic Transmission Shift Lock Control Auto-Automatic Aux- Auxiliary avg-Average A4WD-Automatic Four-Wheel Drive AWD- All-Wheel Drive AWG-American Wire Gage B B+-Battery Positive Voltage BARO-Barometric Pressure BAS- Brake Apply Sensor BATT-Battery BBV--Brake Booster Vacuum BCA-Bias Control Assembly BCM-Body Control Module BFC- Body Function Controller BHP-Brake Horsepower BLK-Black blts- Belts BLW- Brake Lining Wear BLU-Blue Bn- Bank BP-Back Pressure BPCM-Battery Pack Control Module BPMV-Brake Pressure Modulator Valve BPP-Brake Pedal Position BRN-Brown (BTCM) Brake Torque Control Module BTDC-Before Top Dead Center BTM-Battery Thermal Module BTSI-Brake Transmission Shift Interlock Btu-British Thermal Units C °C-Degrees Celsius CAC-Charge Air Cooler CAFE-Corporate Average Fuel Economy Cal-Calibration calc- Calculated Cam-Camshaft CAN- Controller Area Network CARB-California Air Resources Board CASE- Crankshaft Angle Sensor Error cass- Cassette CC-Coast Clutch CC- Climate Control cm³-Cubic Centimeters CCM-Convenience Charge Module, Chassis Control Module CCOT-Cycling Clutch Orifice Tube CCP-Climate Control Panel CCW- Counter Clockwise CD-Compact Disc CDX- Compact Disc Changer CE-Commutator End CEAB-Cold Engine Air Bleed CEMF-Counter Electromotive Force CEX-Cabin Exchanger cfm-Cubic Feet per Minute cg-Center of Gravity CID-Cubic Inch Displacement CKP-Crankshaft Position CKT-Circuit C/Ltr-Cigar Lighter CL-Closed Loop CLS-Coolant Level Switch cm- Centimeter cmd- Command CMC-Compressor Motor Controller cmmd- Commanded CMP-Camshaft Position CNG-Compressed Natural Gas CO-Carbon Monoxide CO2-Carbon Dioxide Coax-Coaxial COMM-Communication compl- Complete(d) cond- Condition config- Configuration Conn-Connector const- Constant COP- Computer Operating Properly CPA-Connector Position Assurance CPP-Clutch Pedal Position CPS-Central Power Supply CPU-Central Processing Unit CRT-Cathode Ray Tube CRTC-Cathode Ray Tube Controller CS-Charging System CSFI-Central Sequential Fuel Injection CTD- Content Theft Deterrent CTP-Closed Throttle Position CTP- Closed Throttle Position ctrl- Control ctsy- Courtesy cu ft-Cubic Foot/Feet cu in-Cubic Inch/Inches CV-Constant Velocity Joint CVRSS-Continuously Variable Road Sensing Suspension Cyl-Cylinder(s) D D- Drive DAB-Delayed Accessory Bus dB-Decibels dBA=Decibels on A-weighted Scale dBm- Decibel Meter DC-Direct Current, Duty Cycle DCM-Door Control Module DDM- Driver Door Module DDS- Driver Door Switch DE-Drive End DEC-Digital Electronic Controller dec- Decrement Decal- Decelerate def- Defrost defog- Defogger deg- Degrees deg C- Degrees Celsius del- Delivered DERM-Diagnostic Energy Reserve Module DERM- Diagnostic Energy Reserve Module des- Desired DFCO- Decel Fuel Cut-Off DI-Distributor Ignition dia-Diameter Diag- Diagnostic DIC-Driver Information Center Diff-Differential dig- Digit DIM-Dash Integration Module dis- Disable disc- Disconnect discrim- Discriminate disp- Display DK-Dark DLC-Data Link Connector DMCM-Drive Motor Control Module DMM-Digital Multi-meter DMSDS-Drive Motor Speed and Direction Sensor DMU-Drive Motor Unit DNR- Dolby Noise Reduction DOHC-Dual Overhead Camshafts Dol- Dolby Dr- Door DR, Drvr-Driver DRL-Daytime Running Lamps DRP- Dynamic Rear Proportioning DRR- Digital Radio Receiver drvr- Driver DSM- Driver Seat Module DSP- Digital Signal Process DTC-Diagnostic Trouble Code DVD- Digital Video disc Dwn Down E EBCM-Electronic Brake Control Module EBM- Electronic Brake Module EBTCM-Electronic Brake and Traction Control Module E&C-Entertainment and Comfort EC-Electrical Center, Engine Control EC- Engine Control ECC-Electronic Climate Control ECI-Extended Compressor at Idle ECL-Engine Coolant Level ECM-Engine Control Module, Electronic Control Module Econ- Economy ECS-Emission Control System ECT-Engine Coolant Temperature ECU- Electronic Control Unit EEPROM-Electrically Erasable Programmable Read Only Memory EEVIR-Evaporator Equalized Values in Receiver EFE-Early Fuel Evaporation EGR-Exhaust Gas Recirculation EGR TVV-Exhaust Gas Recirculation Thermal Vacuum Valve EHCU- Electric Hydraulic Control Unit EHPS-Electro-Hydraulic Power Steering EI-Electronic Ignition ELAP-Elapsed ELC-Electronic Level Control elec- Electric E/M-English/Metric EMB- Electromagnetic Brake EMF-Electromotive Force EMI-Electromagnetic Interference enab- Enabled Eng-Engine EOP-Engine Oil Pressure EOT-Engine Oil Temperature EPA-Environmental Protection Agency EPR-Exhaust Pressure Regulator EPS- Electric Power Steering EPROM-Erasable Programmable Read Only Memory EQ- Equalizer ERH- Extended Ride Height ESB-Expansion Spring Brake ESC-Electronic Suspension Control ESD-Electrostatic Discharge ESM- Electronic Steering Module ESN-Electronic Serial Number EST- Electronic Spark Timing ESO- Engine Shutoff Est- Estimated ETC-Electronic Throttle Control ETC-Electronic Temperature Control ETC-Electronic Timing Control ETCC-Electronic Touch Climate Control ETR-Electronically Tuned Receiver ETS-Enhanced Traction System EV- Electric Vehicle EVAP-Evaporative Emission evap- Evaporator EVO-Electronic Variable Orifice ext- Extended Extr- Exterior Exh-Exhaust F °F-Degrees Fahrenheit F4WD- Full-Time Four-Wheel Drive FC-Fan Control fdbk- Feedback FDC-Fuel Data Center FED-Federal All United States except California FEDS-Fuel Enable Data Stream FEIC- Fuel Economy Integrated Counter FET- Field Effect Transistor FEX-Front Exchanger FF-Flexible Fuel FFH-Fuel-Fired Heater FI-Fuel Injection FICM- Fuel Injector Control Module filt- Filter FL- Front Left flr-Floor FM- Frequency Modulation FMVSS-Federal U.S. Motor Vehicle Safety Standards FP-Fuel Pump FP- Fuel Pump FPR- Fuel Pump Regulator FR- Front Right freq- Frequency frnt- Front FRP- Fuel Rail Pressure ft-Foot/Feet FT-Fuel Trim FTP- Fuel Tank Pressure F4WD-Full Time Four-Wheel Drive 4WAL-Four-Wheel Antilock 4WD-Four-Wheel Drive FW-Flat Wire FWD-Front Wheel Drive, Forward G g/cyl- Grams per cylinder g-Grams, Gravitational Acceleration GA-Gage, Gauge gal-Gallon gas-Gasoline GCW-Gross Combination Weight Gen-Generator GL-Gear Lubricant GM-General Motors GM SPO-General Motors Service Parts Operations gnd-Ground gpm-Gallons per Minute GPS- Global Positioning System GRN-Green GRY-Gray GS- Garage Shift GVWR-Gross Vehicle Weight Rating H H-Hydrogen H2O-Water Harn-Harness HC-Hydrocarbons HCM- Heating Control Module H/CMPR-High Compression HD-Heavy Duty HDC-Heavy Duty Cooling hex-Hexagon, Hexadecimal Hg-Mercury HI- High Hi Alt-High Altitude HID- High Intensity Discharge hist- History HO2-SHeated Oxygen Sensor horiz- Horizontal hp-Horsepower HPL-High Pressure Liquid HPS-High Performance System HPV-High Pressure Vapor HPVS-Heat Pump Ventilation System hr- Hour hrs- Hours HTCM- HVAC Thermal Control Module Htd-Heated HTR-Heater HUD-Head-up Display HVAC-Heater-Ventilation-Air Conditioning HVACM-Heater-Vent-Air Conditioning Module HVIL-High Voltage Interlock Loop HVM-Heater Vent Module H/W- Hardware HW- Heated Windshield Hz-Hertz I IA- Intake Air IAC-Idle Air Control IAT-Intake Air Temperature IC-Integrated Circuit, Ignition Control ICCS-Integrated Chassis Control System ICDX- Integrated Compact Disc Changer ICM-Ignition Control Module ICS- Integrated Chassis System ID-Identification, Inside Diameter IDI-Integrated Direct Ignition IGBT-Insulated Gate Bi-Polar Transistor ign-Ignition ILC-Idle Load Compensator I/M- Inspection and Maintenance IMDX- Integrated Mini Disc Changer immo- Immobilizer IMRC- Intake Manifold Runner Control IMT- Intake Manifold Tuning In- Inches inadv- Inadvertent inc- Increment incand- Incandescent infl- Inflatable info- Information init- Initial in-Inch/Inches INJ-Injection inst-Instantaneous, Instant int- Interior I/O- In/Out I/P- Instrument Panel IP-Instrument Panel IPC-Instrument Panel Cluster IPM-Instrument Panel Module I/PEC-Instrument Panel Electrical Center IRQ)-Interrupt Request ISC-Idle Speed Control iso- Isolation ISO-International Standards Organization ISS-Input Speed Shaft, Input Shaft Speed K KAM-Keep Alive Memory KDD-Keyboard Display Driver kg-Kilogram kg/h- Kilograms per hour kHz-Kilohertz km-Kilometer km/h-Kilometers per Hour km/l-Kilometers per Liter kPa-Kilopascals KS-Knock Sensor kV-Kilovolts L L-Liter L4F-our Cylinder Engine, In-Line L6-Six-Cylinder Engine, In-Line lb-Pound lb ft-Pound Feet Torque lb in-Pound Inch Torque LCD-Liquid Crystal Display LCM- Lighting Control Module LDCL-Left Door Closed Locking LDCM-Left Door Control Module LDM-Lamp Driver Module l duty- Light Duty LED-Light Emitting Diode LEV-Low Emissions Vehicle LF-Left Front LFWS- Left Front Wheel Speed LGM- Lift Gate Module LH- Left Hand LMD- Left Mid Door lm-Lumens LO- Low LPG- Liquefied Petroleum Gas LPS- Low Pressure Sensor L/R- Left Rear LR-Left Rear LT-Left LT-Light LT-Long Term LTPI-Low Tire Pressure Indicator LTPWS-Low Tire Pressure Warning System lvl- Level M MAF-Mass Air Flow malf- Malfunction MALL- Multifunction Alarm Lighting and Locking man- Manufacturer Man-Manual MAP-Manifold Absolute Pressure MAT-Manifold Absolute Temperature max-Maximum M/C-Mixture Control MCU- Microprocessor Control unit MD- Mini Disc MDP-Manifold Differential Pressure MDX- Mini Disc Changer med- Medium mem- Memory MFI-Multiport Fuel Injection mi-Miles mid- Midrange MIL-Malfunction Indicator Lamp min-Minimum MIN-Mobile Identification Number mL-Milliliter mm-Millimeter mm3- Cubic Millimeters mmhg- Millimeters of mercury MMM- Memory Mirror Module mod- Module mon- Monitor mpg-Miles per Gallon mph-Miles per Hour ms-Millisecond MSM- Memory Seat Module MST-Manifold Surface Temperature MSVA-Magnetic Steering Variable Assist, Magnasteer® M/T-Manual Transmission/Transaxle mtr- Motor mult- Multiple mux- Multiplex MV-Megavolt mV-Millivolt N N- Neutral NAES-North American Export Sales nav- Navigation NC-Normally Closed NDH- Navigation Display Head NEG-Negative Neu-Neutral NGO- Natural Gas Operation NI-Neutral Idle NiMH-Nickel Metal Hydride NLGI-National Lubricating Grease Institute Nm-Newton-meter Torque NO-Normally Open NOx-Oxides of Nitrogen NPTC-National Pipe Thread Coarse NPTF-National Pipe Thread Fine NOVRAM-Non-Volatile Random Access Memory NR- Noise Reduction NSBU- Neutral Safety Back Up NV- Night Vision NVRAM- Non-Volatile Random Access Memory O O2-Oxygen O2S-Oxygen Sensor OAT- Outside Air Temperature OBD-On-Board Diagnostics OBD II-On-Board Diagnostics Second Generation OBPA- Off-Board Programming Adaptor OC-Oxidation Converter Catalytic OCS-Opportunity Charge Station OD-Outside Diameter ODM-Output Drive Module ODO-OdometerOEOriginal Equipment OEM-Original Equipment Manufacturer OHC-Overhead Camshaft ohms-Ohm OL-Open Loop, Out of Limits ORC-Oxidation Reduction Converter Catalytic orig- Original ORN-Orange ORVR-On-Board Refueling Vapor Recovery OSC- Oxygen Storage Capacity Overtemp- Over temperature OSS-Output Shaft Speed Oz-Ounce(s) P P- Park PAG-Polyalkylene Glycol PAIR-Pulsed Secondary Air Injection parms- Parameters PC- Pressure Control (solenoid valve), PASS, PSGR-Passenger PASS-Key®-Personalized Automotive Security System P/B-Power Brakes PC-Pressure Control PCB-Printed Circuit Board PCM-Powertrain Control Module PCMCIA- Personal Computer Memory Card Industry Association PCS-Pressure Control Solenoid PCV-Positive Crankcase Ventilation PDIF- Pressure Differential PDM- Passenger Door Module PDS- Passenger Door Switch PEB-Power Electronics Bay perf- Performance phn- Phone PID-Parameter Identification PIM-Power Inverter Module PIN- Personal Identification Number PLL- Phase Locked Loop PM-Permanent Magnet Generator PMV- Pressure Modulator Valve P/N-Part Number PNK-Pink PNP-Park/Neutral Position pm-Parts per Million POA-Pilot Operated Absolute Valve POS-Positive, Position POT-Potentiometer Variable Resistor PPL-Purple PPS- Passenger Presence Setting press- Pressure preten- Pretensioner prev- Previous prim- Primary PRNDL-Park, Reverse, Neutral, Drive, Low Prog- Program PROM-Programmable Read Only Memory P/S- Power Steering PS-Power Steering PSCM-Power Steering Control Module, Passenger Seat Control Module PSD-Power Sliding Door psgr- Passenger PSP-Power Steering Pressure psi-Pounds per Square Inch psia-Pounds per Square Inch Absolute psig-Pounds per Square Inch Gauge PSIR- Passenger Supplemental Inflatable Restraint PSM- Passenger Seat Module PSP- Power Steering Pressure pt-Pint PTC-Positive Temperature Coefficient PTO- Power Take Off PWM-Pulse Width Modulated pwr- Power PZM- Platform Zone Module Q QDM-Quad Driver Module Qt-Quart(s) R R- Reverse R-12-Refrigerant-12 R-134a-Refrigerant-134a R/A- Resume or Accelerate RAC- Remote Accessory Controller RAM- Random Access Memory ran- Random RAM-Random Access Memory, Non-permanent memory device, memory contents are lost when power is removed. RAP-Retained Accessory Power RAV-Remote Activation Verification RCC- Rear Climate Control RCDLR-Remote Control Door Lock Receiver RDCM-Right Door Control Module RDS- Radio Display System rec- Receive recal- Recalibrate, Recalibration recap- Receptacle Recirc- Recirculation recl- Recline Ref-Reference Rev-Reverse ref- Reference refrig- Refrigeration regen- Regenerate req- Request resist- Resistance resync- Resynchronize rev- Reverse REX-Rear Exchanger RF-Right Front, Radio Frequency RFA-Remote Function Actuation RFI-Radio Frequency Interference RFWS- Right Front Wheel Speed RH-Right Hand RIM-Rear Integration Module RKE-Remote Keyless Entry Rly-Relay RMD- Right Mid Door ROM-Read Only Memory, Permanent memory device, memory contents are retained when power is removed. RPA- Rear Parking Assist RPM-Revolutions per Minute Engine Speed RPO-Regular Production Option RR-Right Rear RRD- Right Rear Door RSA- Rear Seat Audio RSS-Road Sensing Suspension RTC- Real-Time Clock RTD-Real Time Damping RT-Right RTT- Reconfigurable Telltale RTV-Room Temperature Vulcanizing Sealer RWAL-Rear Wheel Antilock RWD-Rear Wheel Drive RWS- Rear-Wheel Steer RVAC- Rear Video/Audi/HVAC Module S s-Second(s) SAE-Society of Automotive Engineers SBM- Standard Body Module SC-Supercharger SCB-Supercharger Bypass SCM-Seat Control Module SCV- Speed Controlled Volume SDL- Serial Data Link SDM-Sensing and Diagnostic Module sec- Second(s) sen- Sensor SEO-Special Equipment Option seq- Sequence ser- Serial SFI-Sequential Multiport Fuel Injection SI-System International Modern Version of Metric System SIAB-Side Impact Air Bag sig- Signal SIR-Supplemental Inflatable Restraint SIS- Side Impact Sensor SLA-Short/Long Arm Suspension SMCC- Stepper Motor Cruise Control SOD- Side Object Detection SOH- State of Health sol-Solenoid SO2-Sulfur Dioxide SP-Splice Pack S/P-Series/Parallel spd- Speed speedo- Speedometer (SPI) Serial Peripheral Interface SPO-Service Parts Operations SPS-Service Programming System sq ft, ft²-Square Foot/Feet sq in, in²-Square Inch/Inches SRC-Service Ride Control SRI-Service Reminder Indicator SRS-Supplemental Restraint System SS- Speed signal SS-Shift Solenoid SSS- Speed Sensitive Steering SSV- Shift Solenoid Valve ST-Scan Tool stdby- Standby STID-Station Identification Station ID STL- Service Transmission Lamp SUV- Sport Utility Vehicle SVS- Service Vehicle soon S/W- Software S4WD-Selectable Four-Wheel Drive Sw-Switch SWC- Steering Wheel Controls SWPS-Steering Wheel Position Sensor SXR- Serial Transmit and Receive sync- Synchronize sys- System T TA- Traffic Announcement TAC-Throttle Actuator Control Tach-Tachometer TAP-Transmission Adaptive Pressure, Throttle Adaptive Pressure TAS- Trap Alert System TAV- Transmission Adaptive Volume TBC- Truck Body Controller TBI- Throttle Body Injection TBI-Throttle Body Fuel Injection TC-Turbocharger, Transmission Control TCC-Torque Converter Clutch TCM- Transmission Control Module TCS-Traction Control System TDC-Top Dead Center tele- Telescope TEMP-Temperature Term-Terminal TFP-Transmission Fluid Pressure TFT-Transmission Fluid Temperature THM-Turbo Hydro-Matic TIM-Tire Inflation Monitoring, Tire Inflation Module TIS- Techline Information System TOC-Transmission Oil Cooler torq- Torque TP-Throttle Position TPA-Terminal Positive Assurance TPM-Tire Pressure Monitoring, Tire Pressure Monitor TR-Transmission Range TRANS-Transmission/Transaxle trac- Traction (trans) Transmission trk- Truck TSS- Turbine Shaft Speed TT-Tell Tail Warning Lamp TTM- Tilt and Telescope Module TV- Television TV-Throttle Valve TVAM) Television Antenna Module TVRS-Television and Radio Suppression TVV-Thermal Vacuum Valve TWC-Three Way Converter Catalytic TWC+OC-Three Way + Oxidation Converter Catalytic TXV-Thermal Expansion Valve twtr- Tweeter U UART-Universal Asynchronous Receiver Transmitter U/H-Under hood U/HEC-Under hood Electrical Center U-joint-Universal Joint unlk- Unlock UTD-Universal Theft Deterrent UV-Ultraviolet V V-Volt(s), Voltage V6-Six-Cylinder Engine, V-Type V8-Eight-Cylinder Engine, V-Type Vac-Vacuum VAC-Vehicle Access Code VATS-Vehicle Anti-Theft System VCIM-Vehicle Communication Interface Module VCM-Vehicle Control Module V dif-Voltage Difference VDOT-Variable Displacement Orifice Tube VDR- Vehicle Dealer Recorder VDV-Vacuum Delay Valve veh- Vehicle vel-Velocity ver- Version vert- Vertical VES-Variable Effort Steering VF-Vacuum Fluorescent VIN-Vehicle Identification Number VIO-Violet VIU- Vehicle interface Unit VLR-Voltage Loop Reserve VMV-Vacuum Modulator Valve VR-Voltage Regulator V ref-Voltage Reference VSES-Vehicle Stability Enhancement System vspd- Vehicle speed VSS-Vehicle Speed Sensor VSV) Vacuum Solenoid Valve VTD- Vehicle Theft Deterrent W w/-With warn- Warning W/B-Wheel Base WHL-Wheel WHT-White w/o-Without WOT-Wide Open Throttle W/P-Water Pump W/S-Windshield WSS-Wheel Speed Sensor WU-OC-Warm Up Oxidation Converter Catalytic WU-TWC-Warm Up Three-Way Converter Catalytic X X valve-Expansion Valve Y yd-Yard(s) YEL-Yellow Automotive Network, Inc., Copyright ©2012
