91 buick regal starting problemswillystyles 06-14-2006, 01:22 AM We own this above buick and have had starting issues. The beginning started out with of course will not start and then if you release the tilt wheel it will start. And now will not start with no less than 20 minutes down time. What is causing it and how do I fix my problem please!!!! dreager 07-07-2006, 05:23 PM Recently I had a similar nightmare (lasted 3 weeks).Since I had an alarm installed prior to this I figured thats the bogey. The installer upon checking found the gear selector was not fully engaging in Park.The procedure was to turn ignition to the on position, and pull lever all the way down and jam it back into park. 2 or 3 attempts and the car would start. Now I'm considering dismanlting neutral safety switch on tranny to adjust selector......all points in that direction.Done it before so it's a 10 min. job. Lazy right now lol. Another thing to consider is the indicator switch in steering column. I had problems there about 7 months ago. In both these cases there are electrical/copper contacts which wear.The main contact (selector) which runs over all 5 (PND21)of them tends to weaken with age. I just pushed down on it and it fixed the problem.Use contact cleaner and put lottsa goop in it and you're done.I was quoted $268 for the part at NAPA..... lolol It's always a good idea to refer back to what jobs/repairs were done last, and follow the trail. Automotive Network, Inc., Copyright ©2012
