Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Dodge > Neon/Plymouth Neon > 1st Gen 95-99
Old 06-11-2006, 10:54 PM   #1
WhiteShadow050
WhiteShadow050 Normal reputation
92 Neon will not go in reverse
I recently bought a manual 92 Neon. The reverse worked just fine before i bought it, however after a day or 2 of driving it quit. Its a 5 speed.
WhiteShadow050 is offline   Reply With Quote
Old 06-12-2006, 01:41 AM   #2
Wollf
Wollf's Avatar
Wollf Normal reputation
Re: 92 Neon will not go in reverse
usually thats not a good thing , dont know what to tell you here , dont park anywhere you have to back out of ..... ?
I work as a partsman in the BC Area if you need help finding something you cant find pm me here and i will see what i can do. www.lordco.com
Better to sit in silence and be thought stupid , then to open your mouth and remove all doubt.
Wollf is offline   Reply With Quote
Old 06-12-2006, 09:59 AM   #3
das2123
Tuning Neons since '97
das2123's Avatar
das2123 Normal reputation
Send a message via AIM to das2123 Send a message via Yahoo to das2123
The neon came out in 95, so you don't have a 92. Check your shifter cables.
das2123 is offline   Reply With Quote
Old 06-12-2006, 10:23 AM   #4
HPNOTIQracing
HPNOTIQracing Normal reputation
if it where the cables he would have lost other gears also i cant remember which ones tho
HPNOTIQracing is offline   Reply With Quote
Old 06-12-2006, 10:33 AM   #5
das2123
das2123's Avatar
What about bushings and/or retaining clips?
Old 06-12-2006, 11:03 PM   #6
wnt2rd
wnt2rd Normal reputation
The shift cables connect to the transmission with O-shaped plastic rings. There are rubber bushings that bridge the gap between the plastic of the rings and the metal of the transmission. By now your bushings are probably gone because I have a 95, too, and mine are gone. The only way I could get my car in reverse without the bushings is by pushing the clutch in all the way and slowly putting the car into reverse--and I would still hear a little grinding.
Dodge will probably sell you new bushings. I'm going to contact Dodge once I get my transmission back in the car so I can get nice, new bushings.
If you don't want to spend the money you can always surround the metal parts of the transmission that connect to the shift levers with duct tape or something--I don't know.
wnt2rd is offline   Reply With Quote
Old 06-13-2006, 09:30 AM   #7
das2123
das2123's Avatar
Get some booger bushings from http://www.boogerracing.com/ . They are cheaper than the dealer and SO MUCH BETTER. You can also pick your color of boogers
Old 06-13-2006, 12:04 PM   #8
HPNOTIQracing
+1 WITH BOOGERS i eat em all the time.
Old 06-13-2006, 02:37 PM   #9
das2123
das2123's Avatar
They take some getting used to, but they work great!
Old 06-16-2006, 05:41 AM   #10
FemaleRacer
FemaleRacer Normal reputation
ok-just curious gentlemen-can bushing that are starting to go bad cause a Neons tranny to momentarily stall between some or all gears?
Don't let the 34JJ's and 6" heels throw you off...I race to win. No games. Just you in my rearview mirror
FemaleRacer is offline   Reply With Quote
Old 06-16-2006, 09:29 AM   #11
das2123
das2123's Avatar
If they are worn, they won't allow the cables to their jobs correctly. If the cable can't work correctly, the tranny may not be able to shift correctly.
Old 06-16-2006, 03:57 PM   #12
FemaleRacer
As always Das-thanks for your valuable expertise
Old 06-17-2006, 05:10 PM   #13
wnt2rd
Ooh! I'm going to get the red ones! NEAT-O!
Bookmarks
Google
Web AF
