95 Cutless Supreme Air Condition Issue Need Helps281er238 06-10-2006, 08:31 PM Hi I Hvae A 95 Cutlesss Supreme Whenever I Turn On The Air Condition On Workes Perfect Cold Air But As Soon As I Step On The Gas Pedal When I Driving It Wont Blow Air From The Front Vents And As Soon As I Let Go Of The Gas Pedal It Blow Air From The Vents Again Anyone Had This Issue What Could It Be Vacum Leak Need Advice Please GTP Dad 06-11-2006, 07:29 AM This is a vacuum issue. The actuator for the vents is vacuum controlled and may be going bad causing it to close when the vacuum is high. It is located under the dash and can be easily replaced. s281er238 06-16-2006, 07:35 PM Need More Help On This Issue Automotive Network, Inc., Copyright ©2012
