Tbi to carb question ?fuzzypuppy 06-08-2006, 06:11 PM Ok, I have searched past messages for this but no luck, so at the risk of re'hashing an old topic, Is there anybody out there who has switched from Tbi to carb? I have a 91 2500 5.7 4l80e, w/ 198k on her, I now live in a state w/no smog testing, in the next month or so I am going to be putting it up on blocks for much needed repairs, one of which is to swap to some vortec heads I have, in looking for a new intake maniflod and larger Tbi to go with the new heads I have started thinking about the tbi swap. I remember a guy on this board who was talking and asking about this very same swap "though on an older truck" but I never saw any further postings on this at all. I'm pretty sure its possable but was wondering how the computer reacted to it, as far as timing, etc? I already have good cold air intake, headers magnaflow exhaust and an Edelbrock cam installed, and though the truck performs pretty well I can tell It needs fed a bit more, after I install the better flowing heads it will no doubt starve for more fuel/air. I would like to hear from someone who has made this swap successfully, or if it was not a success. I would appreciate some advice here, Thanks wafrederick 06-08-2006, 07:10 PM Stay with the tbi and fuel injection runs better than a carburator fuzzypuppy 06-10-2006, 05:26 PM Ok Wafrederick, you think "stay w/ Tbi? runs better?, I honestly would like to hear the details. the reason I wanted to swap are several, carbs are cheaper all the way around, me being an old school hotrod type person can tune in a Holly or a carter in a hot tick, which brings up the fact that I can tune the thing w/o a puter hooked up to it or chipping it, as well I can tune it to what I want not what the puter thinks it should be, if I want economy, or max hp I can tune it there, I can get a pack of jets for a carb pretty reasonable instead of new injectors etc, which are expensive. I have the same problem with my truck as so many on this site do, "the infamous (roaming idle)", though it's not too bad anymore, I dont want it at all, and as of now after alot of testing and ruling out suspected bad parts I can only believe it is caused by the computers slow speed, ie, the sensing and subsequent adjustment of timing, and air fuel mixture by the slow computer, I never had the roaming idle problem with a cab engine. The cam I installed in the truck was very limited by the computer and Tbi, I would like more cam to go with my new vortec heads, not a ton just a bit, but have been informed by every speed shop cam/engine tech that the cam I have now is at the very limit of what the computer and Tbi can calibrate to. I am looking to pull as close to 400 hp out of this engine as I can after the overhaul I am planning. I have researched Tbi mods and yes I can have my tbi bored out and surfaced, new high psi injectors, new computer chipping etc,to bring myTbi up to a 650 cfm range, for the cost of around $650.00, not including the new after market fuel pump etc. But then again after all this I would be stuck as to what it is, tuning is still very limited. In defence of the Tbi settup I have to say they are pretty low maintainance and help fuel econemy. I would love to stick with my stock Tbi because this is going to be a budget rebuild and I do like the MPG, but I have not found a way to get the Hp/torque #'s that I would like out of my stock unit on this budget, hell if it wasn't for the budget I would go TPI, imo, this is really the only way to have the best of both worlds hp/torque + mpg. This is why I posted here, I'm at a bit of a crossroads and stuck on this one point. I believe I have a great starting point for a decient build, strong 4 bolt main small block, nice set of performance heads, the exhaust is tricked, ignition is setup all new MSD, even the trans, though a computer controled 4L80e it is completely beefed, my only soft point and where I'm completely at odds is my fuel/air delivery, I'm open to segestions if you or anyone else knows a way I have not found yet to achieve my goals, not knowing if it is even possably yet I reverted back to what I know and it's a carb, cheap and can get me closer to 400 HP. Anyhow thanks for looking and I do appreciate your response or any others I may get. maybe I should post in the performance section, I think I'll try that as well. wafrederick 06-10-2006, 05:51 PM Fuel injection is a whole lot better.You can get more horsepower with fuel injection.Edelbrock sells a tbi to multi port fuel injection set up for the 1988- 1995 throttle bodied fullsize trucks,350s and 454s.Edelbrock claims better mpg and horsepower fuzzypuppy 06-13-2006, 05:17 PM Thanks for the info wafrederick, I'll check it out, I have checked out some owner operater type shops that say they will build my Tbi better, but the cost is unreal, especialy when I look at other websites and can get a nice Edelbrock carb for no more than $150.00, "used" but hell I used to get and swap used carbs with my buddies all the time. I looked into a 454 Tbi and was given spec's that though possable it was really not the way to go, Iguess I'll keep weighing the options. Thanks for the info. Automotive Network, Inc., Copyright ©2012
