93 cutlass ciera stalll
2000RT
06-07-2006, 10:58 PM
As requested here is a new thread. How do you check the crank position sensor using a VOM meter ? If it cannot be done that way how else do you check it?
maxwedge
06-08-2006, 09:37 AM
Get a scanner on it and see if you have cranking rpms, if none the cps or ign module. The procedure is outlined at autozone.com/repairinfo
2000RT
06-19-2006, 03:38 PM
I have replaced the ECM . Now the car starts and run a bit better, but it seems that the idle speed is low. How do youincrease curb idle speed. I tried the turn ignition on then off method fron the haynes manual. Does the TPS affect idle speed or just cruising speed?:screwy: :screwy:
maxwedge
06-19-2006, 08:32 PM
Idle relearn may take a few miles of driving try this first, also let it idle in gear for a few minutes. Proper tps operation can affect idle speed also.
