Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Chevrolet > Blazer
Old 06-07-2006, 08:07 PM   #1
kramer840
kramer840 Normal reputation
'98 blazer tune up
howdy! i'm a novice when it comes to cars. i have a '98 blazer with 139k miles. i know it needs a tune up, but i'm not sure what's involved. how much does one normally cost? what parts are needed? and would it be less expensive to buy the parts myself and then take them to a mechanic? thanks.
kramer840 is offline   Reply With Quote
Old 06-07-2006, 08:13 PM   #2
muzzy1maniac
muzzy1maniac's Avatar
muzzy1maniac Normal reputation
Re: '98 blazer tune up
Welcome
It is always cheaper to do things yourself - unless ya really screw something up!!
Blazer owners learn that you either need a healthy bank account to pay someone to repair them or ya learn how to do it yourself.
Tune ups are easy..
Plugs(use AC/Delco platinums)
Wires
PCV
Air filter
You don't need to adjust the timming on 98's.
Hope that helps a bit. You can use the search feature and find some pretty detailed help on just about everything.
2004 Explorer XLT
4.0L 4x4
1998 Ranger Supercab
4x2 3.0L
Anyone who said There Is No Such Thing As A Stupid Question never worked in a grocery store!
Come visit me on www.faceforums.com
muzzy1maniac is offline   Reply With Quote
Old 06-07-2006, 09:05 PM   #3
DINO55
DINO55's Avatar
DINO55 Normal reputation
Also Add to the full Tune up list....
New AC Delco Distributor Cap & Rotor
New Fuel filter
Oil & filter change
1998 BLAZER LS Vin-W 4Dr 2wd
2004 Cavalier LS 4Dr 2.2 Ecotec
"Good Part's ain't Cheap--Cheap Parts ain't Good"
DINO55 is offline   Reply With Quote
Old 06-07-2006, 10:23 PM   #4
SComp23
SComp23 Normal reputation
I did my tune up for around $225 US in March. BE CAREFUL with the distributor cap screws, they put a bunch of loctite on the things and the cap holes break, its a sumbitch to fix, I ended up JB Welding my cap to my distributor.
SComp23 is offline   Reply With Quote
Old 06-07-2006, 11:06 PM   #5
BlazerLT
AF -Advisor
BlazerLT's Avatar
BlazerLT Normal reputation
Also, and oil change is not a tuneup item, it is a regular maintance item.
1995 Factory Blazer Service Manual for sale, PM if interested.
BlazerLT is offline   Reply With Quote
Old 06-08-2006, 05:32 AM   #6
DINO55
DINO55's Avatar
My Mistake.
All this time I thought most engines perform a little better with clean oil in them. I must have been wrong.
Old 06-08-2006, 08:55 AM   #7
muzzy1maniac
New Fuel filter
Oil & filter change
Thanks for the catch..
2004 Explorer XLT
4.0L 4x4
4x2 3.0L
Old 06-08-2006, 03:22 PM   #8
BlazerLT
AF -Advisor
BlazerLT's Avatar
My Mistake.
It does, but it isn't a tuneup item at all.
Kinda like changing your transmission fluid or flushing your coolant system.
Old 06-08-2006, 04:23 PM   #9
MT-2500
AF - Advisor
MT-2500's Avatar
MT-2500 +50
Well a tune up or asking for a tune up is getting obsolete in the car repair world.
Not that you do not need to do one it is people usually run them until they are not running right or check engine light comes on before they think about it.
Also car manufactures are pushing the 100K spark plugs.
Which is a bummer because there is a lot of other maintenance ideas that need done before then.
The flat books gives from 1.5 to 2 hrs labor for a minor tune up.
It includes compression check and check or replace and plugs, cap and wires and air filter, adjust timing and idle speed if it applies to vehicle. Plus the fuel filter/fuel pressure check or computer performance is extra.
If you have 139K on it check plugs cap and wires and fuel filter and fuel pressure.
If any check engine light also check computer system.
Also at that mileage there are a lot of other maintenance ideas that probably need checked to.
Do you have a service history of maintenance work done on it?
MT
MT
MT-2500 is online now   Reply With Quote
Bookmarks
Google
Web AF
