Automotive Forums .com - the leading automotive community online! Visit IgorSushko.com and see what it's like racing in Japan
Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Chevrolet > S-10
Old 06-07-2006, 12:02 PM   #1
jimmyv-21
jimmyv-21's Avatar
jimmyv-21 Normal reputation
how to disable fuel pump
does anyone know an easy way to disable a fuel pump on a 98 s10 w/ 2.2?
i have tried the fuses under the hood- but they disable more than just the fuel pump. thanks
jimmyv-21 is offline   Reply With Quote
Old 06-07-2006, 12:27 PM   #2
busa4
busa4 Normal reputation
Re: how to disable fuel pump
removed the fuel pump relay.
busa4 is offline   Reply With Quote
Old 06-07-2006, 03:38 PM   #3
jimmyv-21
jimmyv-21's Avatar
where would that be on a 98?
Old 06-07-2006, 03:40 PM   #4
busa4
check your fuse/relay box in the engine compartment.
Old 06-07-2006, 03:44 PM   #5
jimmyv-21
jimmyv-21's Avatar
i have read that the relay is behind the glove box- pulled it off but i dont know what i am looking for.
Old 06-07-2006, 06:11 PM   #6
Disturbed_One
Disturbed_One Normal reputation
Send a message via MSN to Disturbed_One
probably a stupid question...why do you want to disable it?
The Toys:
1992 GMC Sonoma, 4.3L V6 - 5spd Manual [My Baby]
1988 Chevy Nova, 1.6L I4 - 3spd Auto
1999 Chevy Venture, 3.4L V6 - 4spd Auto
1996 Dodge Stratus, 2.4L I4 - 4spd Auto
1979 Chevy Monza, 5.8L V8 - 3spd Auto
Disturbed_One is offline   Reply With Quote
Old 06-07-2006, 10:22 PM   #7
spivey-1
spivey-1 Normal reputation
I'm kind of like distrubed one why disable it but really none of my business. and yes the relays are in the glove compartment more than likely there will be three but i really cant tell u which one for sure but i think it is the middle one
spivey-1 is offline   Reply With Quote
Old 06-08-2006, 01:31 PM   #8
jimmyv-21
jimmyv-21's Avatar
i am doing a professional fuel injection cleaning in which you prime the system with fuel and then using the fuel pressure test port, you start the car using a fuel injection cleaner that taps in at the fuel pressure test port- cleaner goes directly to the injectors. to do this you must disable the fuel pump- on many gm cars there is a single fuse to do this. on my s10, if you pull the fuse under the hood, you disable more than the fuel pump. i need to know what i am looking for behind the glove box that looks like a relay???
Old 06-08-2006, 01:50 PM   #9
busa4
look for this....
Old 06-08-2006, 03:54 PM   #10
jimmyv-21
jimmyv-21's Avatar
no luck- not behind glovebox. the one under the hood in the fuse box is similar but controls more than just the fuel pump.
Old 06-08-2006, 04:33 PM   #11
busa4
i checked my 98 s10 with a 4.3 and it is a minature 4 pin relay that only controls the pump. it is located in the engine compartment center fuse relay box next to the abs unit. the fuse/relay cover should tell you what the relay controls. a 4 pin relay cannot control more than 1 devise.
Bookmarks
Google
Web AF
