Re: Changing Spark Plugs VW Passat 2002
I have a 2000 Passat V6 30v engine. The plugs are fairly easy to change, though if its the first time you've changed the plugs, the wire boots will be tough to remove. You do need to remove the plastic covers (via the 1/4 turn fasteners). If you are replacing the spark plug wires, be sure to replace them one at a time to maintain the correct firing order (it sounds like a no-brainer until you make that mistake once).
