Automotive Forums .com - the leading automotive community online! Visit IgorSushko.com and see what it's like racing in Japan
Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Chevrolet > Avalanche/C&K/Silverado/Suburban/Tahoe > C/K
Old 06-06-2006, 08:49 AM   #1
donnap1957
donnap1957 Normal reputation
Orfice Tube
I've got 1996 Silverado, 350, on the A/C where is the orfice tube located?
donnap1957 is offline   Reply With Quote
Old 06-06-2006, 10:52 AM   #2
2000CAYukon
2000CAYukon Normal reputation
Re: Orfice Tube
Inside the hard line that goes from the condensor to the evaporator.
//2000CAYukon
2000CAYukon is offline   Reply With Quote
Old 06-06-2006, 03:51 PM   #3
MT-2500
AF - Advisor
MT-2500's Avatar
MT-2500 Normal reputation
Re: Orfice Tube
What is the air cond doing or not doing? Why are you looking for the orfice tube?
MT
MT
MT-2500 is offline   Reply With Quote
Old 06-06-2006, 11:17 PM   #4
donnap1957
Re: Orfice Tube
MT
My A/C crapped out on me . I have installed new comp. and drier and wanted to locate the orfice tube to see if any trash which I'm sure there will be. Should I be allright if I clean the hoses real good and presure it up.
Old 06-07-2006, 09:02 AM   #5
MT-2500
AF - Advisor
MT-2500's Avatar
Re: Orfice Tube
A good flush and make sure you get the proper amount and right oil in it and the proper freon and charge in it.
Also pull a good vacume on system before recharge.
Here is some stuff you will need.
MT
http://www.ackits.com/merchant2/merc...uct_Code=66773
http://www.ackits.com/merchant2/merc...e=DIY-STARTER1
http://www.ackits.com/merchant2/merc...ode=DIYADVANCE
MT
Old 06-11-2006, 06:43 PM   #6
texmex
texmex Normal reputation
Re: Orfice Tube
An easy way to get to the orfice tube on that truck is to remove the front right blinker. It should have four phillips head screws that hold it on located on the exterior of the truck. Behind it there is a hard line coming out of the condensor with a coupling. Im not sure what side of the coupling it is in but once you get that hard line open it should be right there just inside one end of the line.
texmex is offline   Reply With Quote
Bookmarks
Google
Web AF
