Help!!!????!!
jmschoep
07-30-2002, 11:54 AM
I just bought my Altima a couple weeks ago. It's the 4cyl and the intake sounds really noisey, it's like a growl- especially above 5000 rpm, a friend of mine has the 6 cyl and I think his is also unusually loud when accelerating. Has anyone noticed the same thing? Does it bug anyone else and should I take it in to the dealer and see if there's anything they can do???
PolarCivic
08-31-2002, 03:28 PM
Check your air intake ducts, make sure everything going to and from your air box is tight and secure. Especially check your resonator... I think that is the "muffler" for your intake that reduces noise. If all that checks out, I'd go ahead and inspect your exhaust for any kind of holes/leaks. Chances are if it's growling and noisier on accel, it's probably due to lack of seal somewhere in your engines air circulation.
Coke White SE-i
02-02-2003, 06:22 PM
Well no, first check the fliter. And then you can check everything else. Otherwise, just give it a good cleaning! lol
BIG SMOOTHIE
03-01-2003, 10:49 PM
ther is a swirl valve that opens around 5000 rpm kind of like a secondary air passage to increse hp without loosing low end torque and it makes a noticable noise on accel
kenneyd
03-09-2003, 06:54 PM
check to see if it has an air filter in it, that will make the same noise at about 5300 rpm, and you will also notice the different in power.
