swapping an H22a into a 94 accord ex94accord 06-04-2006, 03:40 PM Hello AF, I am swapping an H22a into my 94 accord ex and I need to know if the axels and motor mounts will match up????????????????????? I have a 4 lug wheel hub if that helps... Please respond!! Matt V. lude_si 06-05-2006, 12:51 PM Well its pretty much a direct swap I'm not sure about the axels but the motor mounts are the same, you will need a new ecu. I have the same car with an h22a the only thing that stinks is its a tighter fit and it hard to work on some things but other than that its fun blowin people away. CivicSpoon 06-05-2006, 01:18 PM You will need to use all Accord mounts except for the drivers side mount. For that you will either need to get the Hasport mount or use the Prelude one. If you use the prelude one, you'll need to shave off some metal from the sides of the mount (the part where the bolt goes through). If I remember correctly (been almost a year since I've done the swap), there is some wiring that needs to be changed around as well. I suggest checking out www.accordinglydone.com (http://www.accordinglydone.com) for more detailed info. 94accord 06-05-2006, 06:45 PM Check out this article http://www.sportcompactcarweb.com/tech/0311scc_accord_h22_engine_swap/ It talks about needing prelude half shafts... Is this different from the CV axels?? Automotive Network, Inc., Copyright ©2012
