Re: A/C and Heater "Control Door" malfunction
Make sure the vacuum source/supply to the dash control is actually providing vacuum. There is a small vacuum line from the left side of the engine, through a check valve, to a "T" fitting where is splits to the HVAC control on the dash and to a spherical vacuum reservoir mounted along the right subframe rail. The vacuum reservoir can crack, split, the hose can break loose, or any of the other tubing or fittings in the line can fail. The hard plastic (nylon) vacuum line from the left side of the intake across the engine is particularly susceptible to failure due to the heat and close quarters. Any loss of vacuum will force the dampers ot the default mode - Defrost.
The blower problem is likely a separate issue. The lower speeds are powered directly by the dash-mounted switch, while the high speed is powered through a High Blower relay. Depending upon the model year, this relay may be mounted along the lower edge of the hood/cowl or in the underhood electrical center (fuse/relay panel).
The failure of the A/C clutch in one of the A/C positions may be a switch or wiring problem.
