1999 Blazer 4WD problems
BlownM3
06-03-2006, 06:22 PM
First let me say that I did read the new write up on non working 4WD. So the service 4WD light came on and it was stuck in AUTO 4WD. I would punch the buttons on the 4 button mode selector switch but nothing would happen, not even blinking lights by the buttons. I replaced the mode selector switch with a brand new unit, didn't change anything. Finally I reset the TCCM by removing the neg battery cable. This worked and it returned to 2HI. The service light came back on. How do I trouble shoot what the problem is? I have heard about the harness getting messed up by battery acid by the battery tray. Also heard about replacing the TCCM and encoder. I also heard about accessing the transfer case trouble codes by jumping pin 13 of the OBD2 connector to ground but mine has no wire landed on pin 13. I think a code scanner is needed for 1999 and up vechiles with the automatic transfer case. Thanks
OverBoardProject
06-04-2006, 12:49 AM
Welcome to Automotive Forums :cheers:
If possible how about running to Autozone and get the codes read for free. Then we'll do our best to help you out.
muddog321
06-04-2006, 12:58 PM
So, the question is does it work now? If so you are done - TCCM got a bad input and I think Microsoft designed the software so the reboot fixed - usually. If it still hangs or light flashes step thru the tests/fixes yourself or take to the dealer. Remember "Auto" only uses 2HI so look at the front stuff and vac lines.
BlownM3
06-04-2006, 01:51 PM
Well the button was stuck on auto and it was in 4hi. I know because it was binding up while turning in the parking lot. I will try to see if the problem is fixed. So sometimes does the "reboot" fix the problem? I was just worried about pushing the buttons and recreating the problem. I guess worse case I will just have to reset the system again. I don't think the scanner at Autozone will work for the transfer case codes. I just returned a loaner OBD2 reader to autozone yesterday for my other car, should have waited I guess.
