2002 Honda Civic EXhambone2002 06-03-2006, 02:59 AM I have a 2002 Honda Civic EX with a D17A2 1.7L SOHC VTECH engine. I am trying to find a turbocharger for it and not having very good luck. If anyone knows where I could find one it would be great. hxgaser 06-05-2006, 07:23 PM Turbo-kits.com. Has one prebuilt to fit 7th gen Civics. If you live in CA, it is not CARB certified. Other option is to do some research and actually put together a setup. Typically, it tends to be a bit cheaper if you know what you are doing. The 7th gen Civics aren't the greatest cars to toy with unless you have some serious "mula". If you do, then look into a K-series swap. Do some research before you plop down some cash. Good luck. hambone2002 06-05-2006, 11:09 PM Thanks A Lot Schister66 06-09-2006, 09:29 AM if you're looking for something simple, easy and overpriced get a kit like ones from www.turbokits.com if you want to get something worthwhile that isn't going to rape your wallet....check out www.honda-tech.com and www.turbod16.com and they will help you find what you need...... build it yourself and you will not only save money, but learn something along the way.... vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
