Front Brake Swap??rental blazer 05-31-2006, 11:23 PM is it possable to change JUST the front rotors and calipers on a 95 blazer to the newer 98 up 2 piston type or will i have to swap the caliper bracket too??? what would be involed if anyone has done this please put in detail what is required to adapt to the newer style Blazer SS 06-01-2006, 11:21 AM Get the bracket! The piston pins on the old style are exposed. On the newer style they are completely enclosed. rental blazer 06-01-2006, 03:07 PM Get the bracket! The piston pins on the old style are exposed. On the newer style they are completely enclosed. thanks ...however could you remind me what the bracket is mounted to.... Blazer SS 06-01-2006, 07:38 PM Two bolts at the back of the hub. rlith 06-02-2006, 07:04 AM You will need Calipers Caliper Frame Pads Rotors Knuckles Hubs w/ integrated ABS New dust shields That is if you want to do it complete and correctly. (did this last year) Automotive Network, Inc., Copyright ©2012
