96 cutlass supreme, trunk won't openjstmeagn 05-30-2006, 04:32 PM key won't go in trunk lock and remote in glove box does not work. anything i can try? wanting to sell, but need to remove items from trunk first. thanks leeshannon 05-31-2006, 01:27 AM Well its kind of cheese to do but....Take back seat out, remove items,install back seat...Sell as is cant get in trunk.No really I have no clue,would get yer stuff out though.....Marshall 95supreme 05-31-2006, 03:48 PM Did you check your fuses? jstmeagn 06-02-2006, 09:47 AM yes, checked all fuses. nothing there. pulled down back seats, too small for large item to fit through. i was hoping there was an emergency release that i could access. i can't find one. anyone have ideas? thanks leeshannon 06-02-2006, 09:42 PM I don't think there is a release any where?. I'm sure you have done this but get a can of WD-40, use the little straw adapter it has on it,and stick it in the lock and spray. You may have to start by spraying the outside first to get the little flap that closes the key hole up to loosen up. Start easing the key in,you may have to jab at it a little to free up the cylinder.Another thing, with the rear seat out if you take a flash light and a real long screw driver or maybe a tire iron with the chisel end on it,reach up to the lock mechanism and try to pry the clasp apart from inside.This just might work especially if you could get the key to go in. My key stuck in the lock in the open position and I had to take the lock mech. off because I couln't get the key out. If you had long enough tools you may be able to reach the screws that hold it together from inside.If you can you could then pry the lock off that way. I know thats not a tech type answer, but if need be think primative as to how to solve the problem. Good luck big guy.....Marshall leeshannon 06-02-2006, 09:51 PM Oh yeh, when you try the push switch in the glove box can you hear it trying to activate the lock in the trunk. If you can hear it trying to work then your lock is probably frozen up,has it been a while since you got in the trunk? If so reach up in the trunk and spray the crap out of the mechanisim from the inside. Also if you don't hear it trying to activate when you use the button in the dash,double check your fuses. Once your sure thats not it the push switch may have failed.Should be easy to buy and real easy to install.Thats all I have,good luck....Marshall XGamesJ6 06-04-2006, 10:02 PM probably got moisture in there, take some WD40 and try to spray it into the lock, get then try your key, and if it seems like some improvement keep repeating, maybe it'll work, i had a similar problem, only it was with the door to my house, it could have gotton rusted, or just a little corrosion from the electric trunk pop. might as well give the WD40 a shot. Automotive Network, Inc., Copyright ©2012
