12v lights on a 6v system
Akira13126
05-29-2006, 04:25 PM
I just bought a 1953 Dodge Truck and was wondering I go about using lights that are 12volts on a 6 volt system. Also what harm would it do to use a 12volt batt instead of a 6volt batt?
Chris
corning_d3
05-29-2006, 04:29 PM
If you install a 12 volt battery, you'll also have to upgrade to an alternator, plus upgrade all 6 volt components. 12 volt lighting on a 6 volt system will be dim.
Akira13126
05-29-2006, 11:15 PM
My other question is, I have to replace the head lights and tail lights because they are missing. Will normal 12volt lighting work w/ it? I also have a set of fogs for it, will those work
Chris
MagicRat
06-03-2006, 12:05 AM
As noted above, 12 volt lights will be unacceptably dim in a 6 volt system.
6 volt headlights and tail light bulbs are still widely available.
http://classicautobulbs.com/
If you convert to 12 volt, you will get better starter and lighting performance and you can use modern electronics (igniton, stereos, etc). However, it can get a bit expensive.
Maintaining the original 6 volt system will keep your truck more original and may enhance its value.
It is possible to use an 8 volt battery and tweak the mechanical style voltage regulator to supprt 8 volts for improved starting performance.
