Automotive Forums .com - the leading automotive community online! Visit IgorSushko.com and see what it's like racing in Japan
Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Chevrolet > S-10
Old 05-28-2006, 06:21 PM   #1
MINDYSUE44
MINDYSUE44 Normal reputation
92 Chevy S - 10 Idle Problem
My 92 S-10 4.3l Idles Rough When I Stop At Lights. Runs Fine Otherwise. When I Stop At A Light It Will Idle Fine Then All The Sudden It Will Kick Down, Lunge Forward And Either Run Very Rough Or Die. When It Dies It Will Start Right Up. I Have Replaced The Egr Valve. I Had The Catalytic Converter Removed And Ran A Straight Pipe Back. Could This Cause The Idle Problem? Please Help
MINDYSUE44 is offline   Reply With Quote
Old 05-28-2006, 08:08 PM   #2
OverBoardProject
Banned
OverBoardProject Normal reputation
Re: 92 Chevy S - 10 Idle Problem
Welcome to Automotive Forums MINDYSUE
You probably have a vaccum leak there. My guess would be close to the EG valve since it was worked on (I assume when the problem started)
If you can take a can of WD40, and start spraying the vaccum hoses in the area you might hear the motor suddenly rev up. If you do the problem is in the area that you just sprayed.
Good luck, they can be hard to find
OverBoardProject is offline   Reply With Quote
Bookmarks
Google
Web AF
