Re: Clear fluid leaking from rear tire assembly
I think the Monroe carries the whole strut kit with strut, boot, mounts, spring and everything in 1-single-unit for around $150 each.
When I did mine early last year, I only replaced with the KYB struts and they were $180 (for 4). If you don't want to play with spring compressor or remove the top strut nut, give Monroe a try
